Ensure that your chassis hardware configuration meets the requirements in Chassis Hardware Requirements.
Admin (a) role privileges in Oracle ILOM are required to view and modify the Sun Blade Zone Manager properties.
The Sun Blade Zone Manager must be enabled in Oracle ILOM.
-> show /STORAGE/sas_zoning/BL0
Targets:
0 (/CH/BL2/HDD0)
1 (/CH/BL2/HDD1)
In this example, the HDD0 and HDD1, which are currently installed in the storage blade server in chassis slot 2, are allocated to the CPU blade server in chassis slot 0.
-> show /STORAGE/BL2/HDD0
Targets:
0 (/CH/BL0)
-> show /STORAGE/BL2/HDD1
Targets:
0 (/CH/BL0)
In this example, the resources HDD0 and HDD1, which are installed in the storage blade server in chassis slot 2, are assigned to the CPU blade server in chassis slot 0.
Method 1: Add or unassign storage resources per CPU blade server.
To assign a storage resource to a CPU blade server, type:
-> cd /STORAGE/sas_zoning/BLn -> set add_storage_access=path_to_storage_device
Where BLn is the CPU blade server chassis slot location, and path_to_storage_device is the path to the storage blade resource.
To unassign a storage resource from a CPU blade server, type:
-> cd /STORAGE/sas_zoning/BLn -> set remove_storage_access=path_to_storage_device
Where BLn is the CPU blade server chassis slot location, and path_to_storage_device is the path to the resource on the storage blade server. For example, /CH/BL1/HDD0.
Method 2: Add or unassign server blade access to storage device.
To assign a CPU blade server to a storage resource, type:
-> cd /STORAGE/sas_zoning/BLn/HDDn
-> set add_host_access=path_to_blade_server
To unassign a host server blade access to a storage device, type:
-> set remove_host_access=path_to_blade_server
Where BLn is the storage blade server chassis slot location, HDDn is the storage resource slot location, and path_to_blade_server is the chassis slot location for the CPU blade server that you want the resource assigned or unassigned. For example, /CH/BL0.
Sun Blade 6000 Modular System Documentation
