Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 4.0.x
Exit Print View
Updated: July 2020
Optionally Modify the Default Network Port 2121 for Storage Redirection
Perform the following procedure to optionally modify the default network port 2121 used by Oracle ILOM for storage redirection.
Before You Begin
  • The following procedure requires access to the Jnlpgenerator-cli file.
    Note - If the Jnlpgenerator-cli file for the storage redirection service was previously configured to run from the web interface, and the Opening Jnlpgenerator-cli file dialog box was previously configured not to display, you will not be able to use the following procedure to change the default storage redirection network port.
  • The Console (c) role is required to run the storage redirection service from the Oracle ILOM web interface.
  • After modifying the default storage redirection port number, Oracle ILOM storage redirection users must always specify the non-default port number when starting, stopping, or viewing storage redirections from the command window or terminal.
To modify the default storage redirection network port 2121, follow these steps:
  1. To access the Jnlpgenerator-cli file, perform one of the following:
    • If the storage redirection service Jnlpgenerator-cli file is installed:
      Open the locally stored Jnlpgenerator-cli file using a text editor.
    • If the storage redirection service Jnlpgenerator-cli file is set to run from web interface:
      1. In the Oracle ILOM web interface, click Remote Control > Redirection > Launch Service.
        The Opening Jnlpgenerator-cli file dialog box appears.
      2. In the Opening Jnlpgenerator-cli dialog box, click “Save to disk,” and then click OK.
      3. In the Save As dialog box, specify a location to store the file, and then click OK.
      4. Using a text editor, open the Jnlpgenerator-cli file stored on the local client system.
  2. Modify the port number argument referenced in the Jnlpgenerator-cli file, and then save the changes to the file.
    File example:
    <application-desc>
    <argument>cli</argument>
    <argument>2121</argument>
    </application-desc>
    After changing the default network port 2121 and saving the changes to the locally stored Jnlpgenerator-cli file, the non-default port number must always be specified when starting, stopping, or viewing storage redirections from the command window or terminal.
