The following procedure provides instructions for disabling a configured alert notification using the Oracle ILOM CLI and web interface. For instructions for configuring and testing alert notifications from an SNMP application client, see View Component Information and the Oracle ILOM Event Log (SNMP) in Oracle ILOM Protocol Management Reference SNMP and IPMI Firmware Release 4.0.x.
Before You Begin
Admin (a) role is required in Oracle ILOM to modify alert notification properties.
Click ILOM Administration > Notifications > Alerts, click a configured Alert ID, and then click Edit. In the Level list box, click Disable, and then click Save.
A successful or failed status message appears.
Type the following to disable a configured alert notification:
set /SP|CMM/alertmgmt/rules/n level=disable
