Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 4.0.x
Exit Print View
Updated: July 2020
Reset BIOS Configuration to Factory Defaults
Before You Begin
  • Perform one of the following actions to reset the BIOS non-volatile data store parameters to factory defaults:
    • From the web interface, click System Management > BIOS, then select Factory from the Reset To Defaults list box and click Save.
    • From the CLI, type: set /System/BIOS reset_to_defaults=factory
    Oracle ILOM resets the BIOS Setup parameters in the non-volatile data store to factory defaults. The Reset To Defaults value reverts to None after the factory default parameters are applied.
Related Information:
