Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 4.0.x
Exit Print View
Updated: July 2020
Test IPv4 and IPv6 Connectivity
To send a network test from the IP and gateway addresses configured in Oracle ILOM to a device on the network, follow this procedure:
  • Perform one of the following:
    • CLI:
      To issue a ping connectivity test from the CLI, type one of the following:
      set /SP|CMM/network/test ping=device_ipv4_address_on network
      set /SP|CMM/network/test ping6=device_ipv6_address_on network
      If the test failed, an error message appears. On some Oracle servers a succeed message appears if the test succeeded.
    • Web:
      To issue a ping connectivity test from the web, do the following:
      1. Click ILOM Administration > Connectivity > Network > Network Tools.
      2. In the tools dialog, select a test type, specify an IP address of a device on the network, then click Test.
Related Information:
