Setting
Next Boot Device on x86 Host Server
Oracle ILOM provides a set of x86 server properties that enables
system administrators to set the next boot device on the host server.
However, these configurable boot device properties in Oracle ILOM,
apply only to the next time the x86 server powers on.
Note - After the system powers on and boots the Oracle ILOM
user-specified boot device, the system reverts to the boot device
properties set in the system BIOS Utility.
System administrators can set the x86 server property for
the next boot device from the Oracle ILOM CLI or web interface.
For more details about using the x86 system next boot device properties
in Oracle ILOM, see the following table.
Note - For details about how to move devices in the boot order
or to make persistent changes to the boot order using the BIOS Utility,
see the BIOS section in the x86 server administration guide for
selecting a boot device. For details about how to move devices in
the boot order or to make persistent changes to the boot order using
the Oracle Hardware Management Pack (HMP) software, see the biosconfig section
in the Oracle Server CLI Tools User's
Guide.
Table 70 Set Next Boot Device Property on x86 Managed Server
Default (Use BIOS Settings)
(boot_device=default) |
Set the Default BIOS property
to have the x86 system boot from the first device that is currently
set in the system BIOS boot order.
CLI Syntax:
Single server:
set /HOST/boot_device=default
Multi-domain server:
set
/Servers/PDomains/PDomain_n/HOST/boot_device=default |
PXE
(boot_device=pxe) |
Set the PXE property to
temporarily bypass the system BIOS boot order at the next host boot
and to boot the x86 system over the network using the PXE boot specification.
CLI Syntax:
Single server:
set /HOST/boot_device=pxe
set
/Servers/PDomains/PDomain_n/HOST/boot_device=pxe |
Disk
(boot_device=disk) |
Set the Disk property to
and to boot the first disk device as determined by the BIOS Utility
boot order.
Note - Use the Disk property to boot from either a fixed hard disk
drive (HDD) or a removable HDD, such as a USB flash device.
CLI Syntax:
Single server:
set /HOST/boot_device=disk
set
/Servers/PDomains/PDomain_n/HOST/boot_device=disk |
Diagnostic
(boot_device=diagnostic) |
Set the Diagnostic property
to temporarily bypass the system BIOS boot order at the next host
boot and to boot the system from the diagnostic partition, if configured.
CLI Syntax:
Single server:
set /HOST/boot_device=diagnostic
set
/Servers/PDomains/PDomain_n/HOST/boot_device=diagnostic |
CDROM
(boot_device=cdrom) |
Set the CDROM property to
and to boot the system from the attached CD-ROM or DVD device.
CLI Syntax:
Single server:
set /HOST/boot_device=cdrom
set
/Servers/PDomains/PDomain_n/HOST/boot_device=cdrom |
Floppy
(boot_device=floppy) |
Set the Floppy property
to temporarily bypass the system BIOS boot order settings at the
next host boot and to boot from the attached floppy device.
CLI Syntax:
Single server:
set /HOST/boot_device=floppy
set
/Servers/PDomains/PDomain_n/HOST/boot_device=floppy |
BIOS
(boot_device=bios) |
Set the BIOS property to temporarily
by-pass the BIOS boot order at the next host boot and to boot the
system to the BIOS Utility Setup Menu.
CLI Syntax:
Single server:
set /HOST/boot_device=bios
set
/Servers/PDomains/PDomain_n/HOST/boot_device=bios |
