Firmware |
The Oracle ILOM Remote System
Console is available on all servers that shipped with Oracle ILOM
3.0.x or Oracle ILOM 3.1.x or have been upgraded from Oracle ILOM
3.0.x or Oracle ILOM 3.1.x to Oracle ILOM 3.2.1 or later. |
KVMS Settings |
Configure the SP local client
properties for keyboard, video, and mouse redirection behavior.
KVMS Defaults:
State: Enabled, Mouse Mode: Absolute, Display Quality: YUV420,
Lock Mode: Disabled
Related Information:
Java Runtime Environment |
The Oracle ILOM Remote System Console requires the Java Runtime Environment to be either Java
7 update 131 or later, Java 8, or Java 9. To download the latest
Java Runtime Environment, go to http://java.com.
Note -
All Java versions support TLS v1.2. However, if a version
prior to Java 7u131 is installed,
you will need to manually enable TLS v1.2 , or update your
system with a later Java version. For information about
configuring TLS properties in Oracle ILOM, see Figure 38, Table 38, Web Server Configuration Properties.
Required JDK and Web Browser |
For
IPv4 networks, the 32-bit JDK is required.
For IPv6 networks, the JDK170b36 or higher is required.
Registration of 32-bit JDK
for Video Redirection |
The 32-bit JDK Java Plug-in
must be registered with the local client web browser prior to using
the Oracle ILOM Remote System Console for video redirection.
User Roles and Host Server
User Credentials |
The
Admin (a) role is required in Oracle ILOM to
modify the KVMS service State.
The Console (c) role is required
in Oracle ILOM to modify KVMS properties (excluding the State property)
and to launch the Oracle ILOM Remote System Console.
Host server user credentials are required to access
the redirected host server.
Video Redirection and Serial Redirection
Use |
When launching the Oracle
ILOM Remote System Console, users can launch the remote KVMS session
using one of the following redirection methods:
Serial
Redirection (Oracle SPARC servers only) – This
option is available for Oracle SPARC server SPs only. When enabled,
Oracle ILOM presents a text-based console for serial host server
redirections.
Video Redirection – This
option is available for Oracle's CMMs, x86 server SPs, and SPARC
server SPs. This option presents a GUI-based console for the video
Communication TCP/IP Ports Required |
uses the following TCP/IP communication ports by default:
Port: 5120 for CD
redirection
Port: 5123 for floppy redirection
Port: 5556 for user authentication redirection
Port: 7578 for video redirection
Port: 7579 for Oracle SPARC server redirection only
Trusted SSL Certficate Support |
As of Oracle ILOM firmware version 3.2.8, additional
certificate checks will occur if the self-signed Default SSL
Certificate is in use. For further information about resolving
certificate warning messages for a default SSL certificate, see:
Resolving Warning Messages for Self-Signed SSL Certificate .
As of Oracle ILOM firmware 3.2.10, additional custom
certificate checks will occur if the custom SSL certificate and
private key are not properly configured. For instance:
A custom Certification Authority (CA) SSL Certificate
and a Private Key are upload to Oracle ILOM.
The Java Keystore on the client side is not properly
configured with the required root CA certificate to
validate the uploaded custom SSL certificate and private
key in Oracle ILOM.
