Network Management Service Deployment Options
Oracle ILOM supports the configuration of several network
management services. Some of these services are enabled by default,
while others require configuration. To better understand which management
services arrive enabled, and which management services are actually
required for your network environment, see the following table.
Note - You should only enable the management services that
are required for your network management environment.
Table 34 Management Access Deployment Options and Default Settings
Web browser client |
HTTPS over port 443 enabled
TLS v1.2 enabled
TLS v1.1 disabled by default.
SSL certificate & self-signing keys
Client timeout session, 15 minutes
FIPS compliance mode disabled
The Web Server management
service in Oracle ILOM, by default, enables a secure communication channel
between a web browser client and the Oracle ILOM SP or CMM.
Network administrators can accept the default web server properties
provided in Oracle ILOM or choose to modify them as needed.
Related Information:
Command-line SSH client |
The SSH Server service in
Oracle ILOM uses server-side keys to encrypt the management channel
between an SSH command-line client and an Oracle ILOM SP or CMM.
Oracle ILOM automatically generates the server-side SSH keys
on the first boot of a factory default system.
SNMP application client
SNMPv3
over port 161, enabled
SNMP sets disabled
User account configuration required
The SNMP management service in Oracle
ILOM offers a secure protocol management solution for monitoring
and managing Oracle servers.
All SNMP monitoring and management functionality is accessible
from an SNMP application, such as Net-SNMP.
Prior to using the SNMP management service in Oracle ILOM,
one or more Oracle ILOM user accounts must be created. Additionally,
prior to using SNMP sets, the SNMP sets property must be enabled.
Oracle ILOM is shipped with SNMPv3 enabled, although administrators
can optionally choose to enable the properties for SNMPv1 or SNMPv2c.
IPMItoolclient |
IPMPv2
over port 623, enabled
IPMI Service state enabled
IPMI 1.5 disabled by default (as of 3.2.4)
The IPMI management service in Oracle
ILOM offers a secure protocol solution for monitoring and managing
Oracle servers.
IPMI monitoring and management functionality is accessible
from the Oracle ILOM CLI using the IPMItool utility.
IPMI configurable properties in Oracle ILOM include the IPMI
management service state and the required user roles (Administrator
or Operator) for performing IPMI management functions from the Oracle
ILOM CLI. Note -
As of firmware 3.2.4, a configurable property for enabling and disabling IPMI 1.5 is provided.
This property is removed from the user interfaces when FIPS mode is enabled.
