Admin (a) role privileges are required in Oracle ILOM to modify Sun Blade Zone Manager properties.
![]() | Caution - Use this procedure only if you want to erase all currently saved SAS zoning allocations in Oracle ILOM. |
-> cd /STORAGE/sas_zoning
-> set reset_access_action=true
If the Zone Manager is disabled, you will get the following warning:
set: The CMM is not the SAS Zone Manager
If you receive this message, enable Zone Manager and re-issue the reset command. For details, see Access and Enable Sun Blade Zone Manager .
