Setting
SPARC Host State Capture
Oracle ILOM provides host state capture properties that enable
system administrators to control the type of data captured if fatal
errors occur. The captured data is stored in Oracle ILOM and is
obtainable when a service snapshot is taken from Oracle ILOM. The
host state capture properties are configurable from the Oracle ILOM
CLI or web interface. For further details about the host state capture configurable
property values, see the following table.
Table 79 Host State Capture Properties for SPARC Server
State Capture on Error
(state_capture_on_error=) |
enabled |
enabled |disabled
That State Capture on Error property controls whether or not
Oracle ILOM collects host state data upon detecting a fatal error
on the host SPARC server.
CLI Syntax for State Capture on
Error:
For SPARC single-server SP, type:
set /HOST state_capture_on_error=enabled|disabled
For SPARC multi-domain server SP, type:
set /Servers/PDomains/PDomains_n/HOST
state_capture_on_error=enabled|disabled |
State Capture Mode
(state_capture_mode=) |
default |
redstate_scandump|
fatal_scandump| default
The State Capture Mode property determines the type of data collected
when an error occurs.
default - When an
error occurs, only error register data is collected and saved to
Oracle ILOM.
fatal Scandump - (Note: This
option is supported on M8 hosts only as of Oracle firmware
version 4.0.1.x) When a Fatal Reset error occurs, error
register and scandump data is collected and saved to Oracle
ILOM. For all other errors, only error register data is
recorded.
redstate Scandump - (Note:
This option is supported on M8 hosts only as of as of Oracle
firmware 4.0.1.x) When a Red State exception occurs, error
recorded.
CLI Syntax for State Capture Mode:
set /HOST state_capture_mode=fatal_scandump|default|redstate_scandump
state_capture_mode=fatal_scandump|default|redstate_scandump |
State Capture Status
(state_capture_status) |
read-only |
The State Capture Status property displays
the current host capture state. Possible status states include:
Enabled = The State
Capture on Error feature is enabled.
Disabled = The State Capture on Error feature is
disabled.
Debug = The State Capture on Error debug feature
is enabled.
Note: The debug feature
can only be set in the Oracle ILOM CLI and is used to run additional
diagnostics when a host fatal error is encountered. The resulting
output is saved to Oracle ILOM and available as part of a service
snapshot
fatal-in-progress =The host has encountered a fatal
error and its current state is being captured
debug-fatal-in-progress = The host has encountered
a fatal error and the debug script is running. This status appears
only when the debug feature is enabled in the Oracle ILOM CLI.
None = There is no status available when the host
is powered off.
