Go to main content
oracle home
Oracle
ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 4.0.x
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Oracle Integrated Lights Out Manager (ILOM) ...
Oracle
ILOM Administrator's ...
Using the Oracle ILOM Remote System Console or ...
Remote System Console First-Time Setup
Register 32-Bit JDK Java Plug-In For Windows ...
Updated: July 2020
Oracle
Document Information
Using This Documentation
Product Documentation Library
Feedback
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Choosing and Configuring a Management Connection to Oracle ILOM
Dedicated Network Management Connection (Default)
Configure a Dedicated Network Management Connection to Oracle ILOM
Sideband Network Management Connection
Configure a Sideband Management Connection to Oracle ILOM
Sideband Management Network Connectivity Considerations
Dedicated Local Management Connection
Configure a Dedicated Local Management Connection to Oracle ILOM
Dedicated Interconnect SP Management Connection
Configuration Methods for Local Interconnect
Auto-Configure a Dedicated Interconnect Management Connection
Manually Configure the Local Interconnect
Host OS Interconnect Guidelines for Manual Configuration
Oracle ILOM SP Interconnect Properties
Management Services and Network Default Properties
Logging In to Oracle ILOM Server SP or CMM
Log In to the Oracle ILOM SP or CMM
Usage Guidelines for IP Network Management Address
Preconfigured User Accounts Enabled by Default
Supported Web Browsers for Oracle ILOM
Configuring Oracle ILOM for Increased Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Supported User Authentication Configuration Options
Assignable Oracle ILOM User Roles
Single Sign-On Service (Enabled by Default)
Maximum Number of User Sessions Supported
Manage User Authenticated Sessions per Managed Device
CLI Authentication Using Local User SSH Key
Security Action: Change Default root Account Password
Password Recovery for Default root Account
Supported File Transfer Methods
Configuring Local User Accounts
Managing Password Policy Restrictions for Local Users
Modify Password Policy Restrictions for Local Users
Password Policy Management Properties and Defaults
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Network Management Service Deployment Options
Network Connectivity Deployment Options
Operating Oracle ILOM in FIPS Compliance Mode
Modify FIPS Mode
FIPS Compliance Mode Effect on ILOM Configuration Properties
Unsupported Features When FIPS Mode Is Enabled
Management of SSH Server State and Weak Ciphers
Use of Web Server Certificates and SSH Server-Side Keys
Default Timeout for CLI and Web Sessions
Management of Banner Messages at Log-In
Create or Update a Banner Message
Delete a Banner Message
Control Message Acceptance Behavior for Login Message
Input Format for IPv4 and IPv6 Addresses
Serial Management Port Owner
Default Network Ports Used by Oracle ILOM
Legacy Oracle Servers Not Supporting IPv6
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Example: Set Up DDNS Configuration
Assigning System Identification Information
Setting ILOM Clock Properties
Suggested Resolutions for Network Connectivity Issues
Resolving Connectivity Issues
Recommended Practice for Spanning Tree Configurations
Test IPv4 and IPv6 Connectivity
Using Remote KVMS Consoles for Host Server Redirection
Oracle ILOM Remote KVMS Consoles Supported
Establishing a Host Serial Console Session to the Server (CLI)
Start Serial Console Redirection and Log In to Host Server OS
Dump Full Console History Contents to Remote Location
Host Serial Console Log Properties
Redirecting an Image File From a Storage Device to the Host Server
Special Considerations for Configuring Host Storage Device Properties
CLI and Web Host Storage Device Properties
Uploading a New Solaris Miniroot Package From SP to Host
System Management Miniroot Property Descriptions
Connecting to the Oracle ILOM Remote System VNC Console
Before You Begin
Establishing an Oracle ILOM Remote System VNC Console Connection
Troubleshooting the VNC Connection
Using the Oracle ILOM Remote System Console or Storage Redirection CLI
Requirements for Using the Oracle ILOM Remote System Console
Configure Local Client KVMS Settings
Register 32-Bit JDK Java Plug-In For Windows IE Web Browser
Register 32-Bit JDK Java Plug-In for Mozilla Firefox Web Browser
Optionally Set a Lock Mode to Secure the Host Server Desktop
Lock Host Desktop When Disconnecting a Remote KVMS Session
Launching and Using the Oracle ILOM Remote System Console
Launch and Use the Oracle ILOM Remote System Console
Remote System Console Menu Options, Usage Considerations, and Toggle Keys
Redirection Menu Options
Devices Menu Options
Device Redirection Usage Considerations
Keyboard Menu Options
Toggle Key Sequence for Keyboard and Mouse Control
International Keyboard Support
Oracle ILOM Storage Redirection CLI
Storage Redirection CLI First-Time Setup
Requirements for Using the Oracle ILOM Storage Redirection CLI
Register Java Plug-In for Windows IE Browser and Start Service for First Time
Start Service For First Time and Register Java Plug-In for Mozilla Firefox Browser
Install the Storage Redirection Client
Optionally Modify the Default Network Port 2121 for Storage Redirection
Launching and Using the Oracle ILOM Storage Redirection CLI
Launch the Oracle ILOM Storage Redirection CLI and Redirect Storage Devices
Interactive and Non-Interactive Shell Syntax
Storage Redirection Commands and Options
Using the Oracle ILOM Remote System Console Plus
Remote System Console Plus First-Time Setup
Requirements for Using the Oracle ILOM Remote System Console Plus
Modify KVMS Maximum Client Session Count (Optional)
Set a Lock Mode to Secure the Host Server Desktop (Optional)
Launching and Using the Oracle ILOM Remote System Console Plus
Launch and Use the Oracle ILOM Remote System Console Plus
Remote System Console Plus Menu Options, Usage Considerations, and Supported Keyboards
KVMS Menu Options
Preference Menu Options
Help Menu Options
Toggle Button, Virtual Keys, and Status Icons
Resolving Warning Messages for Self-Signed SSL Certificate
Resolving Warning Messages for Custom Certification Authority (CA) SSL Certificate
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Host Control and Boot Properties on SPARC Host Server
Overriding SPARC Host Boot Mode
Configuring SPARC Verified Boot Properties
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting SPARC Host State Capture
Managing SPARC Host I/O Reconfiguration Policy
Managing SPARC PDomains and DCU Assignments
Host-DCU Assignments and DCU-SPP Failover Behavior
View DCU Assignments and Manage Failover for DCU-SPP
Set DCU Failover Control for System
DCU Status States
DCU System Failover Properties
PDomain and DCU Assignments
Make DCUs Available For Assignment
Assign Or Unassign DCUs To a PDomain Host
Change Controlling PDomain-SPP for Host (Failover)
Redirecting Host Output to Rear VGA Port
Configuring Alert Notifications, Service Requests, or Remote Logging
Alert Notification Configuration Properties
Configure and Test Alert Notification (IPMI PET, SNMP, or Email)
Disable Alert Notification (IPMI PET, SNMP, or Email)
Configure SMTP Client for Email Alerts
Managing Automatic Service Requests
Configure Oracle ILOM as an ASR Client
Manage Endpoint SSL Certificate Information
Send an ASR Test or Heartbeat Message
ASR Configuration Properties
Configuring Syslog for Event Logging
Configure Syslog IP Address for Event Logging
Setting System Management Power Source Policies and Device Monitoring
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Device Monitoring Configuration Properties
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Set CMM Blade Slot Grant Limit Property
Set SP Power Target Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Set Advanced Power Capping Policy
Setting SP Power Management Settings for Power Policy (SPARC)
Set Power Management Settings for Power Policy on SPARC Servers
Setting the CMM Power Supply Redundancy Policy
Set CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Updating Oracle ILOM Firmware
Firmware Upgradable Devices
Preserve Oracle ILOM Configuration
Before You Begin the Firmware Update
Update the Server SP or CMM Firmware Image
Update Blade Chassis Component Firmware Images
Recover From a Network Failure During Firmware Update
Reset Power to Service Processor or Chassis Monitoring Module
Reset Power to Server SP, NEM SP, or CMM
Managing ASR Component States
Manually Enable or Disable an ASR Component
Managing Active and Standby SP Redundancy Roles (SPARC)
Modify Active and Standby SP Redundancy Roles (SPARC)
SP Redundancy Status Descriptions
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Using Backup, Restore, and Reset Default Operations
User Role Required for Backing Up or Restoring the Oracle ILOM Configuration
Back Up the Oracle ILOM Configuration Settings
Optionally Edit the Oracle ILOM Backup XML Configuration File
Restore the Oracle ILOM Backup XML File
Reset the Oracle ILOM Configuration to Factory Defaults
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Oracle ILOM: BIOS Configuration Features
Oracle ILOM: BIOS Special Considerations
Oracle ILOM: BIOS Terminology
Web and CLI: BIOS Properties
Performing BIOS Configuration Tasks From Oracle ILOM
Requirements for BIOS Configuration Tasks
View the BIOS Configuration Sync Status and Sync the Configuration Parameters
Reset BIOS Configuration to Factory Defaults
Reset Factory Defaults for SP and Oracle ILOM BIOS
Back Up the BIOS Configuration
Restore BIOS Configuration
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Zone Management Using a Third-Party In-Band Management Application
Zone Management Using Oracle ILOM Sun Blade Zone Manager
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Sun Blade Zone Manager Web: Properties
Sun Blade Zone Manager: State
Whole Chassis Setup: Quick Setup
Option 1: Assign to Individual Disks (Quick Setup)
Option 2: Assign to Adjacent Individual Disks (Quick Setup)
Option 3: Assign to Individual Storage Blade (Quick Setup)
Option 4: Assign to Adjacent Storage Blade (Quick Setup)
Full Resource Control: Detailed Setup
Zoning Reset: Reset All
Sun Blade Zone Manager CLI: Targets and Properties
Important SAS Zoning Allocations Considerations
Saving Storage Allocations
Backing Up and Recovering SAS-2 Zoning Assignments
Enabling Zoning and Creating SAS-2 Zoning Assignments
Chassis Hardware Requirements
Access and Enable Sun Blade Zone Manager
Allocating Storage to Entire Chassis: Quick Setup (Web)
Allocate Storage Resources to Single Blade Server: Detailed Setup (Web)
Allocate Single Storage Resource to Multiple Blade Servers: Detailed Setup (Web)
Manually Create SAS-2 Zoning Allocations (CLI)
Managing Existing SAS-2 Storage Resource Allocations
View Existing CPU Blade Server Storage Allocations (Web)
Modify Existing Blade Group Allocations (Web)
View and Modify Existing Storage Allocations (CLI)
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Reset Zoning Allocations to Factory Defaults (Web)
Reset Zoning Allocations to Factory Defaults (CLI)
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
Reset the Zoning Password (Web)
Reset the Zoning Password (CLI)
Index
Index A
Index C
Index D
Index I
Index L
Index N
Index Q
Index S
Index T
Index W
Language:
English
On the Windows Client, open Windows Explorer (not Internet Explorer).
In the Windows Explorer dialog box, click Tools > Folder Options, and then click the Files Types tab.
In the Files Types tab, do the following:
In the Registered File Type list, select the JNLP file type and click Change.
In the Open With dialog box, click Browse to select the 32-bit JDK file.
Select the “Always use the selected program to open this kind of file” check box.
Click OK, and then launch the Oracle ILOM Remote System Console.
For instructions, see
Previous
Next
