Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 4.0.x
Exit Print View
Updated: July 2020
Install the Storage Redirection Client
Perform the following procedure to install the storage redirection client on the local client system:
Note - This is a one-time client installation that needs to be completed before using the Oracle ILOM Storage Redirection CLI for the first time.
Before You Begin
To install the storage redirection client, perform these steps:
  1. In the Oracle ILOM web interface, click Remote Console > Redirection > Download Client.
    The Opening StorageRedir.jar file dialog box appears.
  2. In the Opening StorageRedir.jar dialog box, do the following:
    • Click “Save it to disk,” and then click OK.
    • In the Save As dialog box, save the StorageRedir.jar file to a location on the local client system.
Related Information:
