Serial Management
Port
The serial management
connector (labeled
SER MGT) is an RJ-45 connector
that can be accessed from the rear panel. This port is the default
connection to the server. Use this port only for
server management.
 | Caution - You must use a shielded twisted-pair
(STP) Ethernet cable to maintain your server???s NEBS compliance.
The cable???s shield must be grounded at both ends. |
The default serial connection settings for the serial port
are:
Connector |
SERIAL MGT or l0l0l |
Rate |
9600 baud |
Parity |
None |
Stop bits |
1 |
Data bits |
8 |
The following figure and table describe the pin descriptions
of the SER MGT port.
1 |
5 |
Ground |
2 |
Data Terminal Ready |
6 |
Receive Data |
3 |
Transmit Data |
7 |
Data Set Ready |
4 |
Ground |
8 |
Clear to Send |
If you need to connect to the SERIAL MGT port using a cable
with either a DB-9 or a DB-25 connector, follow the pin descriptions
in the following tables to create a
crossover
adapter appropriate for your serial connection.
Table 10 RJ-45 to DB-9 Adapter Crossovers Wiring Reference
1 |
8 |
CTS |
2 |
DTR |
6 |
DSR |
3 |
TXD |
2 |
RXD |
4 |
Signal Ground |
5 |
Signal Ground |
5 |
Signal Ground |
5 |
Signal Ground |
6 |
RXD |
3 |
TXD |
7 |
DSR |
4 |
DTR |
8 |
CTS |
7 |
RTS |
Table 11 RJ-45 to DB-25 Adapter Crossovers Wiring Reference
1 |
RTS |
5 |
CTS |
2 |
DTR |
6 |
DSR |
3 |
TXD |
3 |
RXD |
4 |
Signal Ground |
7 |
Signal Ground |
5 |
Signal Ground |
7 |
Signal Ground |
6 |
RXD |
2 |
TXD |
7 |
DSR |
20 |
DTR |
8 |
CTS |
4 |
RTS |
