Configure TPM Support
If you intend to use the Windows 2008
TPM feature
set, you must configure the server to support this feature.
Note - TPM enables you to administer the TPM security hardware
in your server. For additional information about implementing this
feature, refer to the Windows Trusted Platform Module Management
documentation provided by Microsoft.
- Access
the BIOS Setup utility menus.
For instructions, see Access the BIOS Setup Utility Menus.
- From the BIOS Main menu screen,
select Advanced.
- From the Advanced Settings screen,
select Trusted Computing.
The Trusted Computing screen appears.
- In the Trusted Computing screen,
select the TCG/TPM Support.
A pop-up dialog box appears.
- In the pop-up dialog box, set
the TCG/TPM Support option to Yes and click Ok.
Note - Even if the TCG/TPM Support was already set to Yes in
the screen shown above, continue on and complete the remaining steps
of this procedure to ensure that all TPM configuration requirements
are satisfied.
The updated Trusted Computing screen appears and shows that
the TCG/TPM Support setting has changed to Yes.
Note - In the above screen, the Execute TPM Command setting
shows the default, Don???t Change.
select the Execute TPM Command option setting.
- In the pop-up tab, set the Execute
TPM Command option to Enabled and click Ok.
the Execute TPM Command setting has changed to Enabled.
- Press the F10 key to save the
changes and exit the BIOS Setup utility.
- To verify that TPM support is
configured, do the following:
- Reboot the server.
- Access the BIOS Setup utility
menus.
- Select Advanced -> Trusted
Computing.
On the Trusted Computing screen, confirm that the TCG/TPM
Support setting is set to Yes and the TPM Enabled/Disable
Status is set to Enabled.
- Press the F10 key to exit BIOS.
