Access the BIOS Setup Utility
Menus
You can access
BIOS Setup utility screens from the following interfaces:
Use a USB keyboard, mouse, and VGA
monitor connected directly to the server.
Use a terminal (or terminal emulator connected to
a computer) through the serial port on the back panel of the server.
Connect to the server using the ILOM Remote Console.
Note - The BIOS Setup utility data is stored in the system???s
battery-backed CMOS RAM. If the data becomes invalid, the BIOS settings
will return to their default, optimal values.
The following task describes the steps for accessing the BIOS
Setup utility menus.
- Power-on
or power-cycle the server.
- To enter the BIOS Setup utility,
press the F2 key when prompted and while the BIOS is running the
power-on self-tests.
Note - If there is an error during the boot process, press
the F1 key to access the BIOS Setup utility.
The
BIOS Setup utility
main screen displays.
- Use the left and right arrow
keys to select the different menu options.
- As you select each menu option,
the top-level screen for that menu option appears.
- To select an option on a top-level
screen, use the up and down arrow keys to scroll up and down the
options presented.
Only options that can be modified are highlighted when you
press the up and down arrow keys.
- If a field
can be modified, as you select the option, user instructions for modifying
the option appear in the right column of the screen.
- If a field is a link to a sub-screen,
instructions to press the Enter key to access the sub screen appear
in the right column.
- Modify the setup field and press
the Esc key to save the changes and exit the screen.
Some screens present a confirmation dialog box that enables
unwanted changes to be retracted.
- On sub-screens that only provide
configuration information and cannot be modified, press the Esc
key to exit the screen.
- To continue modifying other setup
parameters, repeat Step 3 through Step 7. Otherwise,
go to Step 9.
- Press and release the right arrow
key until the Exit menu screen appears.
- Follow the instructions on the
Exit menu screen to save or discard your changes and exit the BIOS
Setup utility.
