You can assign an IP address for the server SP from the BIOS Setup utility on the IPMI LAN configuration menu. Alternatively, you can also specify the LAN settings for the SP using ILOM. For instructions for setting the IP address in ILOM, see the ILOM 3.0 documentation collection.
To set the IP address in the BIOS Setup utility, use the menus to navigate to the LAN configuration setting as follows: Advanced --> IPMI Configuration --> LAN Configuration. See BIOS Setup Utility Menus for the menu navigation tree.
For instructions, see Access the BIOS Setup Utility Menus.
The LAN Configuration screen appears.
