Uncorrectable Error Detected on Last Boot:IOH(0)
Protocol Error (Please Check SP Log for more Details) |
IOH error |
QPI [x] Error (Please Check SP Log for
more Details) |
IOH error |
Note - Where QPI [x] equals 0 for
QPI Link 0 or 1 for QPI Link 1. |
PCI-E [x] Error (Please Check SP Log
for more Details) |
IOH error |
Note - Where PCI-E [x] port number
can range from 1 to 10 depending on the PCI root port on IOH. |
ESI Error (Please Check SP Log for more Details) |
IOH error |
Thermal Error (Please Check SP Log for more Details) |
IOH error |
DMA Error (Please Check SP Log for more Details) |
IOH error |
Miscellaneous Error (Please Check SP Log for more Details) |
IOH error |
VT-d Error (Please Check SP Log for more Details) |
IOH error |
BMC Not Responding |
ILOM error |
Note - This error message might display if during the SP/BIOS
communication an internal error occurs. This error might require you
to restart the SP. |
Primary Slave
Hard Disk Error
Primary Master Hard Disk Error
Secondary Master Hard Disk Error
Secondary Slave Hard Disk Error
IDE/ATAPI error |
Note - These type of error messages display when the BIOS is
attempting to configure IDE/ATAPI devices in POST. |
Timer Error |
8254 timer error |
Note - This type of error typically indicates an error while
programming the count register of channel 2 of the 8254 timer. This could
indicate a problem with system hardware. |
RAM R/W test failed |
Memory test failure |
Note - This type of error typically indicates that the RAM
read/write test failed. |
KBC BAT Test failed |
Keyboard controller basic assurance test error |
Note - Keyboard controller BAT test failed. This error might
indicate a problem with keyboard controller initialization. |
Display memory test failed |
Video display error |
CMOS Battery Low |
CMOS battery error |
Press F2 to enter
BIOS Setup utility to load system defaults.
Check the SP event log in ILOM for more details.
If necessary, replace CMOS battery.
CMOS Checksum
Bad
CMOS Date/Time Not Set
CMOS error |
Password check failed |
Password check error |
Note - This type of error indicates that the password entered
does not match the password specified in the BIOS Setup utility. This
condition might occur for both Supervisor and User password verification. |
Keyboard/Interface Error |
Keyboard controller error |
Note - This type of error indicates that the Keyboard Controller
failure. This error might indicate a problem with system hardware. |
S.M.A.R.T error on the drive |
S.M.A.R.T device error |
Note - Self-Monitoring, Analysis, and Reporting Technology
failure messages might indicate the need to replace the storage device. |
