Exit Print View
The server has four USB ports for attaching supported USB 2.0 compliant devices. USB ports 0 and 1 are on the rear panel and USB ports 2 and 3 are on the motherboard.
Rear Panel Cable Connections
Disconnect Cables From the Server
Reconnect Power and Data Cables
