BIOS Setup
Utility Hot Keys
The
following
table provides
a description of the BIOS Setup utility hot keys and the corresponding
serial connection key combinations.
F1 |
Ctrl+Q (Press and hold the Ctrl key and
type Q) |
Access the BIOS Setup utility if there
is an error during the boot process. Also, access the help menu
from any BIOS menu. |
F2 |
Ctrl+E |
Enter BIOS Setup utility while the system
is performing the power-on self test (POST) |
F7 |
Ctrl+D |
Discard changes and exit BIOS Setup utility |
F8 |
Ctrl+P |
Selects the BBS Popup menu, which allows
you to select a boot device |
F9 |
Ctrl+O |
Load optimal BIOS defaults |
F10 |
Ctrl+S |
Save changes and exit |
F12 |
Ctrl+N |
Boot the server from the network (PXE
boot) |
