Press the Enter key to select
the option.
A confirmation dialog box appears that enables you to save
the changes and exit the Setup utility or cancel the exit option.
Note - The confirmation dialog box is only shown in the following
figure for the Save Changes and Exit option screen. The other exit
confirmation screens work in a similar way.
