gnome-system-monitor - view system processes and monitor system usage
gnome-system-monitor [gnome-std-options]
gnome-system-monitor(1) User Commands gnome-system-monitor(1) NAME gnome-system-monitor - view system processes and monitor system usage SYNOPSIS gnome-system-monitor [gnome-std-options] DESCRIPTION The System Monitor application displays a list of system processes, and monitors system usage. System Monitor shows which processes are running and how the processes are related. System Monitor also provides detailed information about individual pro- cesses, and enables the user to control which processes are running. System Monitor displays how much processor (CPU) capacity the system is using, and how much disk space the system is using on each device. System Monitor displays this information in a graphical interface so that users can see what the system is doing. Users can then use the same graphical interface to modify the behavior of the system. OPTIONS The following options are supported: gnome-std-options Standard options available for use with most GNOME applications. See gnome-std-options(7) for more information. ENVIRONMENT VARIABLES See environ(7) for descriptions of the following environment variables that affect the execution of gnome-system-monitor: NLSPATH. EXIT STATUS The following exit values are returned: 0 Application exited successfully >0 Application exited with failure ATTRIBUTES See attributes(7) for descriptions of the following attributes: +---------------+---------------------------------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+---------------------------------------------+ |Availability | desktop/system-monitor/gnome-system-monitor | +---------------+---------------------------------------------+ |Stability | Pass-through volatile | +---------------+---------------------------------------------+ SEE ALSO System Monitor Manual Latest version of the GNOME Desktop User Guide for your platform. top(1), prstat(8), attributes(7), environ(7), gnome-std-options(7) NOTES Written by Niall Power, Sun Microsystems Inc., 2003. Updated by Henry Zhang, Sun Microsystems Inc., 2006. Source code for open source software components in Oracle Solaris can be found at https://www.oracle.com/downloads/opensource/solaris-source- code-downloads.html. This software was built from source available at https://github.com/oracle/solaris-userland. The original community source was downloaded from https://download.gnome.org/sources/gnome- system-monitor/41/gnome-system-monitor-41.0.tar.xz. Further information about this software can be found on the open source community website at https://help.gnome.org/users/gnome-system-moni- tor/. Solaris 11.4 7 Apr 2017 gnome-system-monitor(1)
