speed - test library performance
openssl speed [-engine id] [md2] [mdc2] [md5] [hmac] [sha1] [rmd160] [idea-cbc] [rc2-cbc] [rc5-cbc] [bf-cbc] [des-cbc] [des-ede3] [rc4] [rsa512] [rsa1024] [rsa2048] [rsa4096] [dsa512] [dsa1024] [dsa2048] [idea] [rc2] [des] [rsa] [blowfish]
SPEED(1openssl) OpenSSL SPEED(1openssl) NAME openssl-speed, speed - test library performance SYNOPSIS openssl speed [-engine id] [md2] [mdc2] [md5] [hmac] [sha1] [rmd160] [idea-cbc] [rc2-cbc] [rc5-cbc] [bf-cbc] [des-cbc] [des-ede3] [rc4] [rsa512] [rsa1024] [rsa2048] [rsa4096] [dsa512] [dsa1024] [dsa2048] [idea] [rc2] [des] [rsa] [blowfish] DESCRIPTION This command is used to test the performance of cryptographic algorithms. OPTIONS -engine id specifying an engine (by its unique id string) will cause speed to attempt to obtain a functional reference to the specified engine, thus initialising it if needed. The engine will then be set as the default for all available algorithms. [zero or more test algorithms] If any options are given, speed tests those algorithms, otherwise all of the above are tested. ATTRIBUTES See attributes(7) for descriptions of the following attributes: +---------------+--------------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+--------------------------+ |Availability | library/security/openssl | +---------------+--------------------------+ |Stability | Pass-through uncommitted | +---------------+--------------------------+ NOTES Source code for open source software components in Oracle Solaris can be found at https://www.oracle.com/downloads/opensource/solaris-source- code-downloads.html. This software was built from source available at https://github.com/oracle/solaris-userland. The original community source was downloaded from https://www.openssl.org/source/openssl-1.0.2za.tar.gz. Further information about this software can be found on the open source community website at https://www.openssl.org/. 1.0.2za 2021-08-24 SPEED(1openssl)
