スイッチには、出力電力状態をモニターできる 0 と 1 の番号が付けられた冗長電源ユニット (PS) があります。このタスクを使用して、個々の PS に関する情報をモニターします。
-> show -d properties /SYS/PS0/OUTPUT_POWER
Properties:
type = Power Unit
ipmi_name = PS0/OUTPUT_POWER
class = Threshold Sensor
value = Disabled
upper_nonrecov_threshold = N/A
upper_critical_threshold = N/A
upper_noncritical_threshold = N/A
lower_noncritical_threshold = N/A
lower_critical_threshold = N/A
lower_nonrecov_threshold = N/A
alarm_status = indeterminate
-> show -d properties /SYS/PS0/I_OUT
/SYS/PS0/I_OUT
Properties:
type = Current
ipmi_name = PS0/I_OUT
value = 14. 750 Amps
alarm_status = cleared
-> show -d properties /SYS/PS0/V_OUT
/SYS/PS0/V_OUT
Properties:
type = Voltage
ipmi_name = PS0/V_OUT
value = 12.00 Volts
upper_nonrecov_threshold = 20.000 Volts
upper_critical_threshold = 14.000 Volts
upper_noncritical_threshold = 50.000 Amps
lower_critical_threshold = 10.000 Volts
