cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawArc_8(mlib_image *buffer, mlib_s16 x,
mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c);
mlib_status mlib_GraphicsDrawArc_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawArc_X_8(mlib_image *buffer, mlib_s16 x,
mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c,
mlib_s32 c2);
mlib_status mlib_GraphicsDrawArc_X_32(mlib_image *buffer, mlib_s16 x,
mlib_s32 c2);
mlib_status mlib_GraphicsDrawArc_A_8(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawArc_A_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawArc_B_8(mlib_image *buffer, mlib_s16 x,
mlib_s32 a);
mlib_status mlib_GraphicsDrawArc_B_32(mlib_image *buffer, mlib_s16 x,
mlib_s32 a);
mlib_status mlib_GraphicsDrawArc_AB_8(mlib_image *buffer, mlib_s16 x,
mlib_s32 a);
mlib_status mlib_GraphicsDrawArc_AB_32(mlib_image *buffer, mlib_s16 x,
mlib_s32 a);
Each of the mlib_GraphicsDrawArc_*() functions draws an arc with the center at (x, y), radius r, start angle t1, and end angle t2.
Each of the mlib_GraphicsDrawArc_X_*() functions draws an arc in Xor mode as follows:
data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawArc_A_*() functions draws an arc with antialiasing.
Each of the mlib_GraphicsDrawArc_B_*() functions draws an arc with alpha blending as follows:
data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsDrawArc_AB_*() functions draws an arc with antialiasing and alpha blending.
Each of the functions takes some of the following arguments:
Pointer to the image into which the function is drawing.
X coordinate of the center.
Y coordinate of the center.
Radius of the arc.
Start angle of the arc in radians.
End angle of the arc in radians.
Color used in the drawing.
Alternation color.
Alpha value for blending. 0 ≤ a ≤ 255.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_GraphicsDrawCircle(3MLIB), mlib_GraphicsDrawEllipse(3MLIB), attributes(5)
