cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageZoomOut2XIndex(mlib_image *dst,
const mlib_image *src, mlib_filter filter, mlib_edge edge,
const void *colormap);
The mlib_ImageZoomOut2XIndex() function minifies the source image by a factor of two. It uses the interpolation method as described by the resampling filter.
The image data type must be MLIB_BYTE or MLIB_SHORT.
The center of the upper-left corner pixel of an image is located at (0.5, 0.5).
The width and height of the destination image can be different from those of the source image.
The center of the source image is mapped onto the center of the destination image.
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
Type of resampling filter. It can be one of the following:
MLIB_NEAREST MLIB_BILINEAR MLIB_BICUBIC MLIB_BICUBIC2
Type of edge condition. It can be one of the following:
MLIB_EDGE_DST_NO_WRITE MLIB_EDGE_DST_FILL_ZERO MLIB_EDGE_OP_NEAREST MLIB_EDGE_SRC_EXTEND MLIB_EDGE_SRC_PADDED
Internal data structure for inverse color mapping. This data structure is generated by the mlib_ImageColorTrue2IndexInit() function.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageZoom(3MLIB), mlib_ImageZoom_Fp(3MLIB), mlib_ImageZoomIn2X(3MLIB), mlib_ImageZoomIn2X_Fp(3MLIB), mlib_ImageZoomIn2XIndex(3MLIB), mlib_ImageZoomIndex(3MLIB), mlib_ImageZoomOut2X(3MLIB), mlib_ImageZoomOut2X_Fp(3MLIB), attributes(5)
