man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalCrossCorrel_F32S (3MLIB)
Name
mlib_SignalCrossCorrel_S16, mlib_SignalCrossCorrel_S16S, mlib_SignalCrossCorrel_F32, mlib_SignalCrossCorrel_F32S - signal cross correlation
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalCrossCorrel_S16(mlib_d64 *correl,
     const mlib_s16 *src1, const mlib_s16 *src2, mlib_s32 n);
mlib_status mlib_SignalCrossCorrel_S16S(mlib_d64 *correl,
mlib_status mlib_SignalCrossCorrel_F32(mlib_d64 *correl,
     const mlib_f32 *src1, const mlib_f32 *src2, mlib_s32 n);
mlib_status mlib_SignalCrossCorrel_F32S(mlib_d64 *correl,
Description
Each of these functions performs cross correlation.
For monaural signals, the following equation is used:
             1    n-1
correl[0] = --- * SUM (src1[i] * src2[i])
             n    i=0
For stereo signals, the following equation is used:
             1    n-1
correl[0] = --- * SUM (src1[2*i] * src2[2*i])
             n    i=0
             1    n-1
correl[1] = --- * SUM (src1[2*i + 1] * src2[2*i + 1])
             n    i=0
Parameters
Each of the functions takes the following arguments:
correl
Pointer to the cross correlation array. In the stereo version, correl[0] contains the cross correlation of channel 0, and correl[1] contains the cross correlation of channel 1.
src1
First source signal array.
src2
Second source signal array.
n
Number of samples in the source signal arrays.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalAutoCorrel_S16(3MLIB), attributes(5)
