cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageChannelMerge(mlib_image *dst,
const mlib_image **srcs);
The mlib_ImageChannelMerge() function converts an array of single-channel images into a multi-channel image.
A0 A1 A2 ... B0 B1 B2 ... ===> A0 B0 C0 A1 B1 C1 A2 B2 C2 ... C0 C1 C2 ...
All images must have the same type, same width, and same height. The data type of the images can be MLIB_BYTE, MLIB_SHORT, MLIB_USHORT, MLIB_INT, MLIB_FLOAT, or MLIB_DOUBLE. The destination image must have the number of channels equal to the number of images in the srcs array. The source images must be single-channel images.
The function takes the following arguments:
Pointer to a multi-channel destination image.
Pointer to an array of single-channel source images.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageChannelCopy(3MLIB), mlib_ImageChannelExtract(3MLIB), mlib_ImageChannelInsert(3MLIB), mlib_ImageChannelSplit(3MLIB), attributes(5)
