man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalLimit_F32_F32(3MLIB)
Name
mlib_SignalLimit, mlib_SignalLimit_S16_S16, mlib_SignalLimit_S16S_S16S, mlib_SignalLimit_S16, mlib_SignalLimit_S16S, mlib_SignalLimit_F32_F32, mlib_SignalLimit_F32S_F32S, mlib_SignalLimit_F32, mlib_SignalLimit_F32S - signal hard limiting
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalLimit_S16_S16(mlib_s16 *dst,
     const mlib_s16 *src, const mlib_s16 *low,
     const mlib_s16 *high, mlib_s32 n);
mlib_status mlib_SignalLimit_S16S_S16S(mlib_s16 *dst,
mlib_status mlib_SignalLimit_S16(mlib_s16 *srcdst,
     const mlib_s16 *low, const mlib_s16 *high, mlib_s32 n);
mlib_status mlib_SignalLimit_S16S(mlib_s16 *srcdst,
mlib_status mlib_SignalLimit_F32_F32(mlib_f32 *dst,
     const mlib_f32 *src, const mlib_f32 *low,
     const mlib_f32 *high, mlib_s32 n);
mlib_status mlib_SignalLimit_F32S_F32S(mlib_f32 *dst,
mlib_status mlib_SignalLimit_F32(mlib_f32 *srcdst,
     const mlib_f32 *low, const mlib_f32 *high, mlib_s32 n);
mlib_status mlib_SignalLimit_F32S(mlib_f32 *srcdst,
Description
Each of these functions performs hard limiting.
For monaural signals, the following equation is used:
dst[i] = low[0]           if src[i] < low[0]
dst[i] = src[i]           if low[0] ≤ src[i] < high[0]
dst[i] = high[0]          if src[i] ≥ high[0]
where i = 0, 1, ..., (n - 1).
For stereo signals, the following equation is used:
dst[2*i] = low[0]         if src[2*i] < low[0]
dst[2*i] = src[2*i]       if low[0] ≤ src[2*i] < high[0]
dst[2*i] = high[0]        if src[2*i] ≥ high[0]
dst[2*i+1] = low[1]       if src[2*i+1] < low[1]
dst[2*i+1] = src[2*i+1]   if low[1] ≤ src[2*i+1] < high[1]
dst[2*i+1] = high[1]      if src[2*i+1] ≥ high[1]
Parameters
Each of the functions takes some of the following arguments:
dst
Destination signal array.
src
Source signal array.
srcdst
Source and destination signal array.
low
Lower input limit. In the stereo version, low[0] contains the lower limit for channel 0, and low[1] contains the lower limit for channel 1.
high
Upper input limit. In the stereo version. high[0] contains the upper limit for channel 0, and high[1] contains the upper limit for channel 1.
n
Number of samples in the source signal array.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
attributes(5)
