man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalIFFT_2_D64_D64C(3MLIB)
Name
mlib_SignalIFFT_2, mlib_SignalIFFT_2_S16_S16_Mod, mlib_SignalIFFT_2_S16C_S16C_Mod, mlib_SignalIFFT_2_S16_S16C_Mod, mlib_SignalIFFT_2_S16_Mod, mlib_SignalIFFT_2_S16C_Mod, mlib_SignalIFFT_2_F32_F32, mlib_SignalIFFT_2_F32C_F32C, mlib_SignalIFFT_2_F32_F32C, mlib_SignalIFFT_2_F32, mlib_SignalIFFT_2_F32C, mlib_SignalIFFT_2_D64_D64, mlib_SignalIFFT_2_D64C_D64C, mlib_SignalIFFT_2_D64_D64C, mlib_SignalIFFT_2_D64, mlib_SignalIFFT_2_D64C - signal Inverse Fast Fourier Transform (IFFT)
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalIFFT_2_S16_S16_Mod(mlib_s16 *dstr,
    mlib_s16 *dsti,
     const mlib_s16 *srcr, const mlib_s16 *srci, mlib_s32 order);
mlib_status mlib_SignalIFFT_2_S16C_S16C_Mod(mlib_s16 *dstc,
    const mlib_s16 *srcc,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_S16_S16C_Mod(mlib_s16 *dstr,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_S16_Mod(mlib_s16 *srcdstr,
    mlib_s16 *srcdsti,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_S16C_Mod(mlib_s16 *srcdstc, mlib_s32 order);
mlib_status mlib_SignalIFFT_2_F32_F32(mlib_f32 *dstr,
    mlib_f32 *dsti,
     const mlib_f32 *srcr, const mlib_f32 *srci, mlib_s32 order);
mlib_status mlib_SignalIFFT_2_F32C_F32C(mlib_f32 *dstc,
     const mlib_f32 *srcc,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_F32_F32C(mlib_f32 *dstr,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_F32(mlib_f32 *srcdstr,
     mlib_f32 *srcdsti,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_F32C(mlib_f32 *srcdstc,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_D64_D64(mlib_d64 *dstr,
     mlib_d64 *dsti,
     const mlib_d64 *srcr, const mlib_d64 *srci, mlib_s32 order);
mlib_status mlib_SignalIFFT_2_D64C_D64C(mlib_d64 *dstc,
     const mlib_d64 *srcc,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_D64_D64C(mlib_d64 *dstr,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_D64(mlib_d64 *srcdstr,
     mlib_d64 *srcdsti,
     mlib_s32 order);
mlib_status mlib_SignalIFFT_2_D64C(mlib_d64 *srcdstc,
     mlib_s32 order);
Description
Each of the functions in this group performs Inverse Fast Fourier Transform (IFFT).
The following equation is used for forward FFT:
          1   N-1
dst[k] = ---- SUM {src[n] * exp(-j2*PI*n*k/N)}
          C1  n=0
and the following equation is used for inverse FFT (IFFT):
          1   N-1
dst[n] = ---- SUM {src[k] * exp(j2*PI*n*k/N)}
          C2  k=0
where
k = 0, 1, ..., (N - 1)
n = 0, 1, ..., (N - 1)
N = 2**order
The signal FFT/IFFT functions can be categorized into four groups according to the ScaleMode in the function names in the following form:
mlib_Signal[FFT|IFFT]_ScaleMode_OutType_InType_OpMode()
mlib_Signal[FFT|IFFT]_ScaleMode_DataType_OpMode()
The scaling factors C1 and C2 used in the equations are defined as follows:
  • For ScaleMode = 1, C1 = 1 and C2 = 2**order.
  • For ScaleMode = 2, C1 = 2**order and C2 = 1.
  • For ScaleMode = 3, C1 = C2 = 2**(order/2) when order is even, or C1 = 2**((order+1)/2) and C2 = 2**((order-1)/2) when order is odd.
  • For ScaleMode = 4, C1 = 2**P and C2 = 2**Q, where P and Q are adaptive scaling factors and are generated by the functions.
For functions with only real parts for the source signal, the imaginary parts are assumed to be all zero. For functions with only real parts for the destination signal, the imaginary parts are discarded. The functions with only one data type in their names perform the operation in place.
Parameters
Each function takes some of the following arguments:
dstr
Destination signal array that contains the real parts.
dsti
Destination signal array that contains the imaginary parts.
srcr
Source signal array that contains the real parts.
srci
Source signal array that contains the imaginary parts.
dstc
Complex destination signal array. dstc[2*i] contains the real parts, and dstc[2*i+1] contains the imaginary parts.
srcc
Complex source signal array. srcc[2*i] contains the real parts, and srcc[2*i+1] contains the imaginary parts.
srcdstr
Source and destination signal array that contains the real parts.
srcdsti
Source and destination signal array that contains the imaginary parts.
srcdstc
Complex source and destination signal array. srcdstc[2*i] contains the real parts, and srcdstc[2*i+1] contains the imaginary parts.
order
Order of the transformation. The base-2 logarithm of the number of data samples.
Return Values
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalFFT_1(3MLIB), mlib_SignalFFT_2(3MLIB), mlib_SignalFFT_3(3MLIB), mlib_SignalFFT_4(3MLIB), mlib_SignalIFFT_1(3MLIB), mlib_SignalIFFT_3(3MLIB), mlib_SignalIFFT_4(3MLIB), attributes(5)
