man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_VideoCopyRefAve_U8_U8_16x16 (3MLIB)
Name
mlib_VideoCopyRefAve_U8_U8_16x16, mlib_VideoCopyRefAve_U8_U8_16x8, mlib_VideoCopyRefAve_U8_U8_8x16, mlib_VideoCopyRefAve_U8_U8_8x8, mlib_VideoCopyRefAve_U8_U8_8x4 - copies and averages a block from the reference block to the current block
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoCopyRefAve_U8_U8_16x16(mlib_u8 *curr_block,
     const mlib_u8 *ref_block, mlib_s32 stride);
mlib_status mlib_VideoCopyRefAve_U8_U8_16x8(mlib_u8 *curr_block,
mlib_status mlib_VideoCopyRefAve_U8_U8_8x16(mlib_u8 *curr_block,
mlib_status mlib_VideoCopyRefAve_U8_U8_8x8(mlib_u8 *curr_block,
mlib_status mlib_VideoCopyRefAve_U8_U8_8x4(mlib_u8 *curr_block,
Description
Each of these functions copies and averages a block from the reference block to the current block. The stride applies to both the input reference block and the current block.
Parameters
Each of the functions takes the following arguments:
curr_block
Pointer to the current block. curr_block must be 8-byte aligned.
ref_block
Pointer to the reference block.
stride
Stride, in bytes, between adjacent rows in both the current block and the reference block. stride must be a multiple of eight.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_VideoAddBlock_U8_S16(3MLIB), mlib_VideoCopyRef_S16_U8(3MLIB), mlib_VideoCopyRef_S16_U8_16x16(3MLIB), mlib_VideoCopyRef_U8_U8_16x16(3MLIB), mlib_VideoCopyRefAve_U8_U8(3MLIB), mlib_VideoH263OverlappedMC_S16_U8(3MLIB), mlib_VideoH263OverlappedMC_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8_16x16(3MLIB), mlib_VideoInterpAveXY_U8_U8(3MLIB), mlib_VideoInterpAveXY_U8_U8_16x16(3MLIB), mlib_VideoInterpAveY_U8_U8(3MLIB), mlib_VideoInterpAveY_U8_U8_16x16(3MLIB), mlib_VideoInterpX_S16_U8(3MLIB), mlib_VideoInterpX_S16_U8_16x16(3MLIB), mlib_VideoInterpX_U8_U8(3MLIB), mlib_VideoInterpXY_S16_U8(3MLIB), mlib_VideoInterpXY_S16_U8_16x16(3MLIB), mlib_VideoInterpXY_U8_U8(3MLIB), mlib_VideoInterpXY_U8_U8_16x16(3MLIB), mlib_VideoInterpY_S16_U8(3MLIB), mlib_VideoInterpY_S16_U8_16x16(3MLIB), mlib_VideoInterpY_U8_U8(3MLIB), mlib_VideoInterpY_U8_U8_16x16(3MLIB), mlib_VideoP64Decimate_U8_U8(3MLIB), mlib_VideoP64Loop_S16_U8(3MLIB), mlib_VideoP64Loop_U8_U8(3MLIB), attributes(5)
