cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_GraphicsFillRectangle_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c);
mlib_status mlib_GraphicsFillRectangle_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c);
mlib_status mlib_GraphicsFillRectangle_X_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsFillRectangle_X_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsFillRectangle_B_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsFillRectangle_B_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c, mlib_s32 a);
Each of the mlib_GraphicsFillRectangle_*() functions draws a filled rectangle with the upper-left corner at (x, y), width w, and height h.
Each of the mlib_GraphicsFillRectangle_X_*() functions draws a filled rectangle in Xor mode as follows:
data[x,y] ^= c ^ c2
Each of the mlib_GraphicsFillRectangle_B_*() functions draws a filled rectangle with alpha blending as follows:
data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the functions takes some of the following arguments:
Pointer to the image into which the function is drawing.
X coordinate of the upper-left corner of the rectangle.
Y coordinate of the upper-left corner of the rectangle.
Width of the rectangle.
Height of the rectangle.
Color used in the drawing.
Alternation color.
Alpha value for blending. 0 ≤ a ≤ 255.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
