man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_GraphicsDrawPolypoint_32(3MLIB)
Name
mlib_GraphicsDrawPointSet, mlib_GraphicsDrawPointSet_8, mlib_GraphicsDrawPointSet_32, mlib_GraphicsDrawPointSet_X_8, mlib_GraphicsDrawPointSet_X_32, mlib_GraphicsDrawPointSet_B_8, mlib_GraphicsDrawPointSet_B_32, mlib_GraphicsDrawPolypoint_8, mlib_GraphicsDrawPolypoint_32, mlib_GraphicsDrawPolypoint_X_8, mlib_GraphicsDrawPolypoint_X_32, mlib_GraphicsDrawPolypoint_B_8, mlib_GraphicsDrawPolypoint_B_32 - draw a set of points
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawPointSet_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsDrawPointSet_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPointSet_X_8(mlib_image *buffer,
     mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsDrawPointSet_X_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPointSet_B_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawPointSet_B_32(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawPolypoint_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolypoint_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolypoint_X_8(mlib_image *buffer,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawPolypoint_X_32(mlib_image *buffer,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawPolypoint_B_8(mlib_image *buffer,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawPolypoint_B_32(mlib_image *buffer,
     mlib_s32 c2);
Description
Each of the mlib_GraphicsDrawPointSet_*() and mlib_GraphicsDrawPolypoint_*() functions draws a set of points at (x1,y1), (x2,y2), ..., and (xn,yn).
Each of the mlib_GraphicsDrawPointSet_X_*() and mlib_GraphicsDrawPolypoint_X_*() functions draws a set of points at (x1,y1), (x2,y2), ..., and (xn,yn) in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawPointSet_B_*() and mlib_GraphicsDrawPolypoint_B_*() functions draws a set of points at (x1,y1), (x2,y2), ..., and (xn,yn) with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
The mlib_GraphicsDrawPolypoint_*() functions are aliases of the mlib_GraphicsDrawPointSet_*() functions.
Parameters
Each of the functions takes some of the following arguments:
buffer
Pointer to the image into which the function is drawing.
x
Pointer to array of X coordinates of the points.
y
Pointer to array of Y coordinates of the points.
npoints
Number of points in the arrays.
c
Color used in the drawing.
c2
Alternation color.
a
Alpha value for blending. 0 ≤ a ≤ 255.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_GraphicsDrawPoint(3MLIB), attributes (5)
