cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageMedianFilterMxN_US(mlib_image *dst,
const mlib_image *src, mlib_s32 m, mlib_s32 n, mlib_median_mask mmask,
mlib_s32 cmask, mlib_edge edge, mlib_s32 bits);
The mlib_ImageMedianFilterMxN_US() function performs MxN median filtering on an MLIB_SHORT type of image that contains unsigned data. Each pixel of the destination image is the pixel with rank middle in the filter window.
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
Width of the filter window. m must be odd number greater than 1.
Height of the filter window. n must be odd number greater than 1.
Shape of the mask to be used for median filtering. It can be one of the following:
MLIB_MEDIAN_MASK_RECT MLIB_MEDIAN_MASK_PLUS MLIB_MEDIAN_MASK_X MLIB_MEDIAN_MASK_RECT_SEPARABLE
Channel mask to indicate the channels to be filtered. Each bit of which represents a channel in the image. The channels corresponded to 1 bits are those to be processed.
Type of edge condition. It can be one of the following:
MLIB_EDGE_DST_NO_WRITE MLIB_EDGE_DST_FILL_ZERO MLIB_EDGE_DST_COPY_SRC MLIB_EDGE_SRC_EXTEND
The number of unsigned bits for pixel dynamic range. 9 ≤ bits ≤ 15.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageMaxFilter3x3(3MLIB), mlib_ImageMaxFilter3x3_Fp(3MLIB), mlib_ImageMaxFilter5x5(3MLIB), mlib_ImageMaxFilter5x5_Fp(3MLIB), mlib_ImageMaxFilter7x7(3MLIB), mlib_ImageMaxFilter7x7_Fp(3MLIB), mlib_ImageMedianFilter3x3(3MLIB), mlib_ImageMedianFilter3x3_Fp(3MLIB), mlib_ImageMedianFilter3x3_US(3MLIB), mlib_ImageMedianFilter5x5(3MLIB), mlib_ImageMedianFilter5x5_Fp(3MLIB), mlib_ImageMedianFilter5x5_US(3MLIB), mlib_ImageMedianFilter7x7(3MLIB), mlib_ImageMedianFilter7x7_Fp(3MLIB), mlib_ImageMedianFilter7x7_US(3MLIB), mlib_ImageMedianFilterMxN(3MLIB), mlib_ImageMedianFilterMxN_Fp(3MLIB), mlib_ImageMinFilter3x3(3MLIB), mlib_ImageMinFilter3x3_Fp(3MLIB), mlib_ImageMinFilter5x5(3MLIB), mlib_ImageMinFilter5x5_Fp(3MLIB), mlib_ImageMinFilter7x7(3MLIB), mlib_ImageMinFilter7x7_Fp(3MLIB), mlib_ImageRankFilter3x3(3MLIB), mlib_ImageRankFilter3x3_Fp(3MLIB), mlib_ImageRankFilter3x3_US(3MLIB), mlib_ImageRankFilter5x5(3MLIB), mlib_ImageRankFilter5x5_Fp(3MLIB), mlib_ImageRankFilter5x5_US(3MLIB), mlib_ImageRankFilter7x7(3MLIB), mlib_ImageRankFilter7x7_Fp(3MLIB), mlib_ImageRankFilter7x7_US(3MLIB), mlib_ImageRankFilterMxN(3MLIB), mlib_ImageRankFilterMxN_Fp(3MLIB), mlib_ImageRankFilterMxN_US(3MLIB), attributes(5)
