man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalConv_S16_S16_Sat (3MLIB)
Name
mlib_SignalConv_S16_S16_Sat, mlib_SignalConv_S16S_S16S_Sat, mlib_SignalConv_F32_F32, mlib_SignalConv_F32S_F32S - signal convolution
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalConv_S16_S16_Sat(mlib_s16 *dst,
     const mlib_s16 *src1, const mlib_s16 *src2, mlib_s32 m,
     mlib_s32 n);
mlib_status mlib_SignalConv_S16S_S16S_Sat(mlib_s16 *dst,
     mlib_s32 n);
mlib_status mlib_SignalConv_F32_F32(mlib_f32 *dst,
     const mlib_f32 *src1, const mlib_f32 *src2, mlib_s32 m,
     mlib_s32 n);
mlib_status mlib_SignalConv_F32S_F32S(mlib_f32 *dst,
     mlib_s32 n);
Description
Each of these functions performs convolution.
For monaural signals, the following equation is used:
         m-1
dst[i] = SUM (src1[j] * src2[i - j])  if m ≤ n
         j=0
         n-1
dst[i] = SUM (src2[j] * src1[i - j])  if m > n
         j=0
where i = 0, 1, ..., (m + n - 2).
For stereo signals, the following equation is used:
               m-1
dst[2*i]     = SUM (src1[2*j] * src2[2*(i - j)])
               j=0
               m-1
dst[2*i + 1] = SUM (src1[2*j + 1] * src2[2*(i - j) + 1])
               j=0
if m ≤ n, or
               n-1
dst[2*i]     = SUM (src2[2*j] * src1[2*(i - j)])
               j=0
               n-1
dst[2*i + 1] = SUM (src2[2*j + 1] * src1[2*(i - j) + 1])
               j=0
if m > n; where i = 0, 1, ..., (m + n - 2).
Parameters
Each of the functions takes the following arguments:
dst
Destination signal array.
src1
First source signal array.
src2
Second source signal array.
m
Number of samples in the first source signal array.
n
Number of samples in the second source signal arrays.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
attributes(5)
