cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageSetPaddings(mlib_image *img, mlib_u8 left,
mlib_u8 top, mlib_u8 right, mlib_u8 bottom);
The mlib_ImageSetPaddings() function sets new values for the paddings field of the mlib_image structure as follows:
img->paddings[0] = left; img->paddings[1] = top; img->paddings[2] = right; img->paddings[3] = bottom;
By default, an image structure creation function, such as mlib_ImageCreate(), mlib_ImageCreateStruct(), or mlib_ImageCreateSubimage(), sets the paddings field of the mlib_image structure as follows:
img->paddings[0] = 0; img->paddings[1] = 0; img->paddings[2] = 0; img->paddings[3] = 0;
Note that this function is needed only when the edge condition MLIB_EDGE_SRC_PADDED is used.
The mlib_image->paddings field denotes the amount of paddings on each side of an image, from which the real image border can be seen. When MLIB_EDGE_SRC_PADDED is specified as the edge condition, a geometric function uses the "real" source image border for clipping the destination image.
The function takes the following arguments:
Pointer to image data structure.
Number of columns padded on the left side.
Number of rows padded on the top.
Number of columns padded on the right side.
Number of rows padded at the bottom.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageGetPaddings(3MLIB), mlib_ImageCreate(3MLIB), mlib_ImageCreateStruct(3MLIB), mlib_ImageCreateSubimage(3MLIB), mlib_ImageAffine(3MLIB), attributes(5)
