cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageMinimum_Fp(mlib_d64 *min, const mlib_image *img);
The mlib_ImageMinimum_Fp() function determines the minimum value for each channel in a floating-point image.
It uses the following equation:
min[i] = MIN{ img[x][y][i]; 0 ≤ x < w, 0 ≤ y < h }
The function takes the following arguments:
Pointer to minimum vector, where length is the number of channels in the image. min[i] contains the minimum of channel i.
Pointer to a source image.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageMaximum(3MLIB), mlib_ImageMaximum_Fp(3MLIB), mlib_ImageMinimum(3MLIB), attributes(5)
