mlib_ImageDataTypeConvert(3MLIB)
Name
- data type conversion
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageDataTypeConvert(mlib_image *dst, const mlib_image *src);
Description
The mlib_ImageDataTypeConvert() function converts between data types MLIB_BIT, MLIB_BYTE, MLIB_SHORT, MLIB_USHORT, MLIB_INT, MLIB_FLOAT, and MLIB_DOUBLE.
The input and output data images must have the same width, height, and number of channels. Conversion to a smaller pixel format clamps the source value to the dynamic range of the destination pixel.
See the following table for available variations of the data type conversion function.
MLIB_BYTE | MLIB_BIT | (x > 0) ? 1 : 0 |
MLIB_SHORT | MLIB_BIT | (x > 0) ? 1 : 0 |
MLIB_USHORT | MLIB_BIT | (x > 0) ? 1 : 0 |
MLIB_INT | MLIB_BIT | (x > 0) ? 1 : 0 |
MLIB_FLOAT | MLIB_BIT | (x > 0) ? 1 : 0 |
MLIB_DOUBLE | MLIB_BIT | (x > 0) ? 1 : 0 |
MLIB_BIT | MLIB_BYTE | (x == 1) ? 1 : 0 |
MLIB_SHORT | MLIB_BYTE | (mlib_u8)clamp(x, 0, 255) |
MLIB_USHORT | MLIB_BYTE | (mlib_u8)clamp(x, 0, 255) |
MLIB_INT | MLIB_BYTE | (mlib_u8)clamp(x, 0, 255) |
MLIB_FLOAT | MLIB_BYTE | (mlib_u8)clamp(x, 0, 255) |
MLIB_DOUBLE | MLIB_BYTE | (mlib_u8)clamp(x, 0, 255) |
MLIB_BIT | MLIB_SHORT | (x == 1) ? 1 : 0 |
MLIB_BYTE | MLIB_SHORT | (mlib_s16)x |
MLIB_USHORT | MLIB_SHORT | (mlib_s16)clamp(x, -32768, 32767) |
MLIB_INT | MLIB_SHORT | (mlib_s16)clamp(x, -32768, 32767) |
MLIB_FLOAT | MLIB_SHORT | (mlib_s16)clamp(x, -32768, 32767) |
MLIB_DOUBLE | MLIB_SHORT | (mlib_s16)clamp(x, -32768, 32767) |
MLIB_BIT | MLIB_USHORT | (x == 1) ? 1 : 0 |
MLIB_BYTE | MLIB_USHORT | (mlib_u16)x |
MLIB_SHORT | MLIB_USHORT | (mlib_u16)clamp(x, 0, 65535) |
MLIB_INT | MLIB_USHORT | (mlib_u16)clamp(x, 0, 65535) |
MLIB_FLOAT | MLIB_USHORT | (mlib_u16)clamp(x, 0, 65535) |
MLIB_DOUBLE | MLIB_USHORT | (mlib_u16)clamp(x, 0, 65535) |
MLIB_BIT | MLIB_INT | (x == 1) ? 1 : 0 |
MLIB_BYTE | MLIB_INT | (mlib_s32)x |
MLIB_SHORT | MLIB_INT | (mlib_s32)x |
MLIB_USHORT | MLIB_INT | (mlib_s32)x |
MLIB_FLOAT | MLIB_INT | (mlib_s32)clamp(x, -2147483647-1, 2147483647) |
MLIB_DOUBLE | MLIB_INT | (mlib_s32)clamp(x, -2147483647-1, 2147483647) |
MLIB_BIT | MLIB_FLOAT | (x == 1) ? 1.0 : 0.0 |
MLIB_BYTE | MLIB_FLOAT | (mlib_f32)x |
MLIB_SHORT | MLIB_FLOAT | (mlib_f32)x |
MLIB_USHORT | MLIB_FLOAT | (mlib_f32)x |
MLIB_INT | MLIB_FLOAT | (mlib_f32)x |
MLIB_DOUBLE | MLIB_FLOAT | (mlib_f32)x |
MLIB_BIT | MLIB_DOUBLE | (x == 1) ? 1.0 : 0.0 |
MLIB_BYTE | MLIB_DOUBLE | (mlib_d64)x |
MLIB_SHORT | MLIB_DOUBLE | (mlib_d64)x |
MLIB_USHORT | MLIB_DOUBLE | (mlib_d64)x |
MLIB_INT | MLIB_DOUBLE | (mlib_d64)x |
MLIB_FLOAT | MLIB_DOUBLE | (mlib_d64)x |
The actions are defined in C-style pseudo-code. All type casts follow the rules of standard C. clamp() can be defined as a macro: #define clamp(x, low, high) (((x) < (low)) ? (low) : (((x) > (high)) ? (high) : (x)))
Parameters
The function takes the following arguments:
- dst
Pointer to destination image.
- src
Pointer to source image.
Return Values
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
Interface Stability | Committed |
MT-Level | MT-Safe |
See also
mlib_ImageReformat(3MLIB), attributes(5)
