cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageCopyMask(mlib_image *dst, const mlib_image *src,
const mlib_image *mask, const mlib_s32 *thresh);
The mlib_ImageCopyMask() function copies one image to another image via a mask image by using it as a yes/no indicator. The data type of the images can be MLIB_BYTE, MLIB_SHORT, MLIB_USHORT, or MLIB_INT.
It uses the following equation:
dst[x][y][i] = src[x][y][i] if mask[x][y][i] ≤ thresh[i] dst[x][y][i] = dst[x][y][i] if mask[x][y][i] > thresh[i]
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
Pointer to mask image.
Threshold for the mask image. thresh[i] contains the threshold for channel i.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageCopy(3MLIB), mlib_ImageCopyArea(3MLIB), mlib_ImageCopyMask_Fp(3MLIB), mlib_ImageCopySubimage(3MLIB), attributes(5)
