cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalDTWVectorInit_F32(void *state,
const mlib_f32 **dref, mlib_s32 lref, mlib_s32 ndata,
mlib_s32 dtype, mlib_s32 delta, mlib_s32 local,
mlib_s32 slope);
The mlib_SignalDTWVectorInit_F32() function initializes the internal state structure for dynamic time warping (DTW) of vector data.
The init function performs internal state structure allocation and global initialization. Per DTW function call initialization is done in DTW function, so the same internal state structure can be reused for multiple DTW function calls.
The function takes the following arguments:
The reference data array.
The length of the reference data array.
The length of each data vector.
The type of distance metric between data vectors. MLIB_DTW_L1NORM for L1 norm of difference (sum of absolute difference). MLIB_DTW_L2NORM for L2 norm of difference (Euclidean distance).
The delta in the endpoint constraints.
The type of the local continuity constraints. MLIB_DTW_ITAKURA for Itakura type constraints.
The type of the slope weighting. MLIB_DTW_NONE for no slope weighting.
Pointer to the internal state structure.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_SignalDTWVectorInit_F32(3MLIB), mlib_SignalDTWVector_F32(3MLIB), mlib_SignalDTWVectorPath_F32(3MLIB), mlib_SignalDTWVectorFree_F32(3MLIB), attributes(5)
