man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_GraphicsDrawLineStripSet_ABG_32(3MLIB)
Name
mlib_GraphicsDrawLineStripSet, mlib_GraphicsDrawLineStripSet_8, mlib_GraphicsDrawLineStripSet_32, mlib_GraphicsDrawLineStripSet_X_8, mlib_GraphicsDrawLineStripSet_X_32, mlib_GraphicsDrawLineStripSet_A_8, mlib_GraphicsDrawLineStripSet_A_32, mlib_GraphicsDrawLineStripSet_B_8, mlib_GraphicsDrawLineStripSet_B_32, mlib_GraphicsDrawLineStripSet_G_8, mlib_GraphicsDrawLineStripSet_G_32, mlib_GraphicsDrawLineStripSet_Z_8, mlib_GraphicsDrawLineStripSet_Z_32, mlib_GraphicsDrawLineStripSet_AB_8, mlib_GraphicsDrawLineStripSet_AB_32, mlib_GraphicsDrawLineStripSet_ABG_8, mlib_GraphicsDrawLineStripSet_ABG_32, mlib_GraphicsDrawLineStripSet_ABGZ_8, mlib_GraphicsDrawLineStripSet_ABGZ_32, mlib_GraphicsDrawLineStripSet_ABZ_8, mlib_GraphicsDrawLineStripSet_ABZ_32, mlib_GraphicsDrawLineStripSet_AG_8, mlib_GraphicsDrawLineStripSet_AG_32, mlib_GraphicsDrawLineStripSet_AGZ_8, mlib_GraphicsDrawLineStripSet_AGZ_32, mlib_GraphicsDrawLineStripSet_AZ_8, mlib_GraphicsDrawLineStripSet_AZ_32, mlib_GraphicsDrawLineStripSet_BG_8, mlib_GraphicsDrawLineStripSet_BG_32, mlib_GraphicsDrawLineStripSet_BGZ_8, mlib_GraphicsDrawLineStripSet_BGZ_32, mlib_GraphicsDrawLineStripSet_BZ_8, mlib_GraphicsDrawLineStripSet_BZ_32, mlib_GraphicsDrawLineStripSet_GZ_8, mlib_GraphicsDrawLineStripSet_GZ_32 - draw line set where each member of the set starts at the point where the previous member ended
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawLineStripSet_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsDrawLineStripSet_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_X_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawLineStripSet_X_32(mlib_image *buffer,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawLineStripSet_A_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_A_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_B_8(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawLineStripSet_B_32(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawLineStripSet_G_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawLineStripSet_G_32(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawLineStripSet_Z_8(mlib_image *buffer,
     mlib_image *zbuffer, const mlib_s16 *x, const mlib_s16 *y,
     const mlib_s16 *z, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsDrawLineStripSet_Z_32(mlib_image *buffer,
     const mlib_s16 *z,
mlib_status mlib_GraphicsDrawLineStripSet_AB_8(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawLineStripSet_AB_32(mlib_image *buffer,
     mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawLineStripSet_ABG_8(mlib_image *buffer,
     const mlib_s32 *c, mlib_s32 a);
mlib_status mlib_GraphicsDrawLineStripSet_ABG_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_ABGZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, const mlib_s32 *c, mlib_s32 a);
mlib_status mlib_GraphicsDrawLineStripSet_ABGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_ABZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawLineStripSet_ABZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_AG_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawLineStripSet_AG_32(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawLineStripSet_AGZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, const mlib_s32 *c);
mlib_status mlib_GraphicsDrawLineStripSet_AGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_AZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_AZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_BG_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_BG_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_BGZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_BGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_BZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_BZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_GZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawLineStripSet_GZ_32(mlib_image *buffer,
     const mlib_s16 *z,
Description
Each of the mlib_GraphicsDrawLineStripSet_*() functions draws a set of lines connecting (x1,y1) with (x2,y2), (x2,y2) with (x3,y3), ..., and (xn-1,yn-1) with (xn,yn).
Each of the mlib_GraphicsDrawLineStripSet_X_*() functions draws a set of lines in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawLineStripSet_A_*() functions draws a set of lines with antialiasing.
Each of the mlib_GraphicsDrawLineStripSet_B_*() functions draws a set of lines with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsDrawLineStripSet_G_*() functions draws a set of lines with Gouraud shading.
Each of the mlib_GraphicsDrawLineStripSet_Z_*() functions draws a set of lines with Z buffering.
Each of the other functions draws a set of lines with a combination of two or more features like antialiasing (A), alpha blending (B), Gouraud shading (G), and Z buffering (Z).
Note that the mlib_GraphicsDrawPolyline_*() functions are aliases of the mlib_GraphicsDrawLineStripSet_*() functions.
Parameters
Each of the functions takes some of the following arguments:
buffer
Pointer to the image into which the function is drawing.
zbuffer
Pointer to the image that holds the Z buffer.
x
Pointer to array of X coordinates of the points.
y
Pointer to array of Y coordinates of the points.
z
Pointer to array of Z coordinates of the points.
npoints
Number of points in the arrays.
c
Color used in the drawing, or pointer to array of colors of the points in the case of Gouraud shading.
c2
Alternation color.
a
Alpha value for blending. 0 ≤ a ≤ 255.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_GraphicsDrawLine(3MLIB), mlib_GraphicsDrawLineSet(3MLIB), mlib_GraphicsDrawLineFanSet(3MLIB), mlib_GraphicsDrawPolyline(3MLIB), attributes(5)
