cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
void mlib_VideoColorYUV411seq_to_YUYV422int(mlib_u32 *YUYV,
     const mlib_u8 *Y,const mlib_u8 *U, const mlib_u8 *V,
     mlib_s32 w, mlib_s32 h, mlib_s32 dlb,
     mlib_s32 ylb, mlib_s32 uvlb);
The Y, U, V pixel streams are combined into a YUYV pixel stream. All pixel components are 8-bit unsigned integers. The Y buffer has dimensions w and h. The U and V buffers have dimensions w/4 and h. Dimension w is assumed to be a multiple of 4. In each row, every 4 Y values use the same U and V values.
The following equation is used:
YUYV[r][c/2]   = (Y[r][c]   << 24) |
                 (U[r][c/4] << 16) |
                 (Y[r][c+1] << 8) |
                 (V[r][c/4])
YUYV[r][c/2+1] = (Y[r][c+2] << 24) |
                 (U[r][c/4] << 16) |
                 (Y[r][c+3] << 8) |
                 (V[r][c/4])
where r = 0, 2, 4, ..., h-2; and c = 0, 2, 4, ..., w-2.
The function takes the following arguments:
Pointer to output buffer.
Pointer to Y input buffer.
Pointer to U input buffer.
Pointer to V input buffer.
Image width in pixels.
Image height in lines.
Linebytes for YUYV buffer.
Linebytes for Y buffer.
Linebytes for U and V buffers.
None.
mlib_VideoColorYUV420seq_to_YUYV422int(3MLIB), mlib_VideoColorYUV422seq_to_YUYV422int(3MLIB), mlib_VideoColorYUV420seq_to_UYVY422int(3MLIB), mlib_VideoColorYUV411seq_to_UYVY422int(3MLIB), mlib_VideoColorYUV422seq_to_UYVY422int(3MLIB), attributes(5)
