cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
void mlib_VideoColorYUYV422int_to_ARGBint(mlib_u32 *ARGB,
     const mlib_u32 *YUYV, const mlib_u8 *A_array, mlib_u8 A_const,
     mlib_s32 w, mlib_s32 h, mlib_s32 dlb, mlib_s32 slb, mlib_s32 alb);
The YUYV pixel stream is converted into an ARGB pixel stream. All pixel components are 8-bit unsigned integers. The YUYV buffer has dimensions w/2 and h. The ABGR buffer has dimensions w and h. Dimensions w is assumed to be even.
The alpha values for this function work in the following fashion:
If A_array pointer is not NULL, the values are taken from there. It has to have the same dimensions as the Y buffer.
If A_array pointer is NULL, the alpha values for every pixel are set to A_const.
The following equation is used:
|R| |1.1644 0.0000 1.5966| [|Y| | 16.0000|] |G| = |1.1644 -0.3920 -0.8132| * [|U| - |128.0000|] |B| |1.1644 2.0184 0.0000| [|V| |128.0000|]
The function takes the following arguments:
Pointer to output buffer.
Pointer to Y input buffer.
Array of alpha values.
Constant alpha value.
Image width in pixels.
Image height in lines.
Linebytes for output buffer.
Linebytes for input buffer.
Linebytes for alpha buffer.
None.
mlib_VideoColorYUV420seq_to_ARGBint(3MLIB), mlib_VideoColorYUV411seq_to_ARGBint(3MLIB), mlib_VideoColorYUV422seq_to_ARGBint(3MLIB), mlib_VideoColorYUV444seq_to_ARGBint(3MLIB), mlib_VideoColorYUV420seq_to_ABGRint(3MLIB), mlib_VideoColorYUV411seq_to_ABGRint(3MLIB), mlib_VideoColorYUV422seq_to_ABGRint(3MLIB), mlib_VideoColorYUV444seq_to_ABGRint(3MLIB), mlib_VideoColorYUV444int_to_ARGBint(3MLIB), mlib_VideoColorYUYV422int_to_ABGRint(3MLIB), mlib_VideoColorYUV444int_to_ABGRint(3MLIB), mlib_VideoColorUYVY422int_to_ARGBint(3MLIB), mlib_VideoColorUYVY422int_to_ABGRint(3MLIB), mlib_VideoColorUYV444int_to_ARGBint(3MLIB), mlib_VideoColorUYV444int_to_ABGRint(3MLIB), attributes (5)
