cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawPolygon_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsDrawPolygon_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_X_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawPolygon_X_32(mlib_image *buffer,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawPolygon_A_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_A_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_B_8(mlib_image *buffer,
     mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawPolygon_B_32(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawPolygon_G_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawPolygon_G_32(mlib_image *buffer,
     mlib_s32 npoints, const mlib_s32 *c);
mlib_status mlib_GraphicsDrawPolygon_Z_8(mlib_image *buffer,
     mlib_image *zbuffer, const mlib_s16 *x, const mlib_s16 *y,
     const mlib_s16 *z, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsDrawPolygon_Z_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_AB_8(mlib_image *buffer,
     mlib_s32 npoints, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawPolygon_AB_32(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawPolygon_ABG_8(mlib_image *buffer,
     const mlib_s32 *c, mlib_s32 a);
mlib_status mlib_GraphicsDrawPolygon_ABG_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_ABGZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, const mlib_s32 *c, mlib_s32 a);
mlib_status mlib_GraphicsDrawPolygon_ABGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_ABZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_ABZ_32(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawPolygon_AG_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawPolygon_AG_32(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawPolygon_AGZ_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawPolygon_AGZ_32(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, const mlib_s32 *c);
mlib_status mlib_GraphicsDrawPolygon_AZ_8(mlib_image *buffer,
     mlib_s32 c);
mlib_status mlib_GraphicsDrawPolygon_AZ_32(mlib_image *buffer,
     mlib_s32 c);
mlib_status mlib_GraphicsDrawPolygon_BG_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_BG_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_BGZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_BGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_BZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_BZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawPolygon_GZ_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawPolygon_GZ_32(mlib_image *buffer,
     const mlib_s32 *c);
Each of the mlib_GraphicsDrawPolygon_*() functions draws a polygon enclosing (x1,y1), (x2,y2), ..., and (xn,yn).
Each of the mlib_GraphicsDrawPolygon_X_*() functions draws a polygon in Xor mode as follows:
data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawPolygon_A_*() functions draws a polygon with antialiasing.
Each of the mlib_GraphicsDrawPolygon_B_*() functions draws a polygon with alpha blending as follows:
data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsDrawPolygon_G_*() functions draws a polygon with Gouraud shading.
Each of the mlib_GraphicsDrawPolygon_Z_*() functions draws a polygon with Z buffering.
Each of the other functions draws a polygon with a combination of two or more features like antialiasing (A), alpha blending (B), Gouraud shading (G), and Z buffering (Z).
Each of the functions takes some of the following arguments:
Pointer to the image into which the function is drawing.
Pointer to the image that holds the Z buffer.
Pointer to the array of X coordinates of the vertices.
Pointer to the array of Y coordinates of the vertices.
Pointer to the array of Z coordinates of the vertices.
Number of vertices in the arrays.
Color used in the drawing, or pointer to array of colors of the points in the case of Gouraud shading.
Alternation color.
Alpha value for blending. 0 ≤ a ≤ 255.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
