man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_VolumeFindMax_U8(3MLIB)
Name
mlib_VolumeFindMax_U8, mlib_VolumeFindMax_S16 - maximum intensity searching
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VolumeFindMax_U8(mlib_u8 *max,
     const mlib_rays *rays);
mlib_status mlib_VolumeFindMax_S16(mlib_s16 *max,
Description
Each function performs maximum intensity searching.
It uses the following equation:
max[i] = MAX{ rays->results[j][i]
              j = 0, 1, ..., rays->nsteps[i] }
where i = 0, 1, ..., rays->nrays - 1.
Parameters
The function takes the following arguments:
max
Pointer to an array of rays->nrays maximum values of the samples in each ray.
rays
Pointer to an mlib_rays structure. The data rays->results are organized with ray number (rather than ray step) varying fastest. Ray number and ray step are the output of the ray casting functions. The data might have values beyond the maximum step on a ray. For example, rays->results[rays->nsteps[i]][i] on ray i might not equal 0.
Return Values
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_VolumeFindMaxBMask_U8(3MLIB), mlib_VolumeFindMaxCMask_U8(3MLIB), attributes(5)
