cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalUpSample_S16_S16(mlib_s16 *dst,
     const mlib_s16 *src, mlib_s32 factor, mlib_s32 phase,
     mlib_s32 n);
mlib_status mlib_SignalUpSample_S16S_S16S(mlib_s16 *dst,
     mlib_s32 n);
mlib_status mlib_SignalUpSample_F32_F32(mlib_f32 *dst,
     const mlib_f32 *src, mlib_s32 factor, mlib_s32 phase,
     mlib_s32 n);
mlib_status mlib_SignalUpSample_F32S_F32S(mlib_f32 *dst,
     mlib_s32 n);
Each of these functions performs upsampling.
For monaural signals, the following equation is used:
dst[i] = src[k] if i == k*factor + phase dst[i] = 0 if i != k*factor + phase
where k = 0, 1, ..., (n - 1); i = 0, 1, ..., (n*factor - 1).
For stereo signals, the following equation is used:
dst[2*i] = src[2*k] if i == k*factor + phase dst[2*i] = 0 if i != k*factor + phase dst[2*i + 1] = src[2*k + 1] if i == k*factor + phase dst[2*i + 1] = 0 if i != k*factor + phase
Each of the functions takes the following arguments:
Output signal array.
Input signal array.
Factor by which to upsample. factor ≥ 1.
Parameter that determines relative position of an input value, within the output signal. 0 ≤ phase < factor.
Number of samples in the input signal array.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
