cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoColorJFIFYCC2RGB422_Nearest(mlib_u8 *rgb,
const mlib_u8 *y, const mlib_u8 *cb, const mlib_u8 *cr, mlib_s32 n);
The mlib_VideoColorJFIFYCC2RGB422_Nearest() function performs color space conversion from YCbCr to RGB together with sampling rate conversion when used in the JPEG File Interchange Format (JFIF).
The function takes the following arguments:
Pointer to destination RGB multi-component row. rgb must be 8-byte aligned.
Pointer to destination Y component row. y must be 8-byte aligned.
Pointer to source Cb component row. cb must be 8-byte aligned.
Pointer to source Cr component row. cr must be 8-byte aligned.
Length of Y component row. n must be even. The length of Cb and Cr component rows must be n/2. The length of the RGB multi-component row must be 3*n.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoColorJFIFYCC2RGB420(3MLIB), mlib_VideoColorJFIFYCC2RGB420_Nearest(3MLIB), mlib_VideoColorJFIFYCC2RGB422(3MLIB), attributes(5)
