man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_GraphicsDrawPoint_X_32 (3MLIB)
Name
mlib_GraphicsDrawPoint, mlib_GraphicsDrawPoint_8, mlib_GraphicsDrawPoint_32, mlib_GraphicsDrawPoint_X_8, mlib_GraphicsDrawPoint_X_32, mlib_GraphicsDrawPoint_B_8, mlib_GraphicsDrawPoint_B_32 - draw point
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawPoint_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 c);
mlib_status mlib_GraphicsDrawPoint_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawPoint_X_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsDrawPoint_X_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawPoint_B_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawPoint_B_32(mlib_image *buffer, mlib_s16 x,
Description
Each of the mlib_GraphicsDrawPoint_*() functions draws a point at (x,y) in color c.
Each of the mlib_GraphicsDrawPoint_X_*() functions draws a point at (x,y) in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawPoint_B_*() functions draws a point at (x,y) with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Parameters
Each of the functions takes some of the following arguments:
buffer
Pointer to the image into which the function is drawing.
x
X coordinate of the point.
y
Y coordinate of the point.
c
Color used in the drawing.
c2
Alternation color.
a
Alpha value for blending. 0 ≤ a ≤ 255.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_GraphicsDrawPointSet(3MLIB), attributes(5)
