man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_VideoInterpAveY_U8_U8_16x16 (3MLIB)
Name
mlib_VideoInterpAveY_U8_U8_16x16, mlib_VideoInterpAveY_U8_U8_16x8, mlib_VideoInterpAveY_U8_U8_8x16, mlib_VideoInterpAveY_U8_U8_8x8, mlib_VideoInterpAveY_U8_U8_8x4 - half-pixel interpolation in the Y direction and averaging for reference block
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoInterpAveY_U8_U8_16x16(mlib_u8 *curr_block,
     const mlib_u8 *ref_block, mlib_s32 frm_stride, mlib_s32 fld_stride);
mlib_status mlib_VideoInterpAveY_U8_U8_16x8(mlib_u8 *curr_block,
mlib_status mlib_VideoInterpAveY_U8_U8_8x16(mlib_u8 *curr_block,
mlib_status mlib_VideoInterpAveY_U8_U8_8x8(mlib_u8 *curr_block,
mlib_status mlib_VideoInterpAveY_U8_U8_8x4(mlib_u8 *curr_block,
Description
Each of these functions performs half-pixel interpolation in the Y direction and averaging for a reference block of data type mlib_u8 and a current block of data type mlib_u8. In this mode, the motion-compensated reference block becomes the current block. Thus, the stride applies to both the input reference block and the current block.
Parameters
Each of the functions takes the following arguments:
curr_block
Pointer to the current block. curr_block must be 8-byte aligned.
ref_block
Pointer to the reference block.
frm_stride
Stride, in bytes, between adjacent rows in a frame in both the current block and the reference block. frm_stride must be a multiple of eight.
fld_stride
Stride, in bytes, between adjacent rows in a field in both the current block and reference block. fld_stride must be a multiple of eight.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_VideoAddBlock_U8_S16(3MLIB), mlib_VideoCopyRef_S16_U8(3MLIB), mlib_VideoCopyRef_S16_U8_16x16(3MLIB), mlib_VideoCopyRef_U8_U8(3MLIB), mlib_VideoCopyRef_U8_U8_16x16(3MLIB), mlib_VideoCopyRefAve_U8_U8(3MLIB), mlib_VideoCopyRefAve_U8_U8_16x16(3MLIB), mlib_VideoH263OverlappedMC_S16_U8(3MLIB), mlib_VideoH263OverlappedMC_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8_16x16(3MLIB), mlib_VideoInterpAveXY_U8_U8(3MLIB), mlib_VideoInterpAveXY_U8_U8_16x16(3MLIB), mlib_VideoInterpAveY_U8_U8(3MLIB), mlib_VideoInterpX_S16_U8(3MLIB), mlib_VideoInterpX_S16_U8_16x16(3MLIB), mlib_VideoInterpX_U8_U8(3MLIB), mlib_VideoInterpXY_S16_U8(3MLIB), mlib_VideoInterpXY_S16_U8_16x16(3MLIB), mlib_VideoInterpXY_U8_U8(3MLIB), mlib_VideoInterpXY_U8_U8_16x16(3MLIB), mlib_VideoInterpY_S16_U8(3MLIB), mlib_VideoInterpY_S16_U8_16x16(3MLIB), mlib_VideoInterpY_U8_U8(3MLIB), mlib_VideoInterpY_U8_U8_16x16(3MLIB), mlib_VideoP64Decimate_U8_U8(3MLIB), mlib_VideoP64Loop_S16_U8(3MLIB), mlib_VideoP64Loop_U8_U8(3MLIB), attributes(5)
