cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VolumeFindMaxCMask_U8(mlib_u8 *max,
const mlib_rays *rays, const mlib_u8 *cmask, mlib_s32 thresh);
mlib_status mlib_VolumeFindMaxCMask_S16(mlib_s16 *max,
Each function performs maximum intensity searching.
It uses the following equation:
max[i] = MAX{ rays->results[j][i]
j = 0, 1, ..., rays->nsteps[i]; cmask[j] > thresh }
where i = 0, 1, ..., rays->nrays - 1.
The function takes the following arguments:
Pointer to an array of rays->nrays maximum values of the samples in each ray.
Pointer to an mlib_rays structure. The data rays->results are organized with ray number (rather than ray step) varying fastest. Ray number and ray step are the output of the ray casting functions. The data might have values beyond the maximum step on a ray. For example, rays->results[rays->nsteps[i]][i] on ray i might not equal 0.
Pointer to an unsigned 8-bit mask array. If cmask[j] > thresh, then data in step j, rays->results[j], are considered.
Threshold.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VolumeFindMax_U8(3MLIB), mlib_VolumeFindMaxBMask_U8(3MLIB), attributes(5)
