cc [ flag... ] file... – lmlib [ library... ] #include <mlib.h>
mlib_status mlib_VolumeRayCast_Blocked_Parallel_Nearest_U8_U8
(mlib_rays *rays, const mlib_blkvolume *
blk, void *buffer);
mlib_status mlib_VolumeRayCast_Blocked_Parallel_Nearest_S16_S16
blk, void *buffer);
mlib_status mlib_VolumeRayCast_Blocked_Parallel_Trilinear_U8_U8
blk, void *buffer);
mlib_status mlib_VolumeRayCast_Blocked_Parallel_Trilinear_S16_S16
(mlib_rays *rays const mlib_blkvolume *
blk, void *buffer);
mlib_status mlib_VolumeRayCast_Blocked_Divergent_Nearest_U8_U8
blk, void *buffer);
mlib_status mlib_VolumeRayCast_Blocked_Divergent_Nearest_S16_S16
blk, void *buffer);
mlib_status mlib_VolumeRayCast_Blocked_Divergent_Trilinear_U8_U8
blk, void *buffer);
mlib_status mlib_VolumeRayCast_Blocked_Divergent_Trilinear_S16_S16
blk, void *buffer);
Each of these functions casts a ray (or rays) through a three-dimensional (3D) data set, then computes and returns the interpolated samples at each step along the way.
In trilinear interpolation, the value at point P is computed from its eight surrounding neighbors based on the equation below.
P = (1-a)*(1-b)*(1-c)*P0 +
a*(1-b)*(1-c)*Px + (1-a)*b*(1-c)*Py + (1-a)*(1-b)*c*Pz +
a*b*(1-c)*Pxy + a*(1-b)*c*Pxz + (1-a)*b*c*Pyz +
a*b*c*Pxyz
where a, b, and c are the fractional parts of the coordinates of point P.
The trilinear interpolation is represented by the following figure:
In nearest neighbor operation, the sample value at point P is replaced by the value of the nearest neighbor voxel.
Each of the functions takes the following arguments:
Casting rays.
Volume data in the blocked format.
Working buffer.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
